reading transmission dipstick
Old May 20, 2010 | 10:50 AM
pianofrk4's Avatar
anyone know how to read the dipstick on the trans for 2007+ sedan? I see the notches, but there is also a meshed/crisscross pattern right above it. is that the threshold? or min./max/service indicator? all this is on the "hot" side. The opposite side of the dipstick has no markings :/
Here are some pix:
Attached Thumbnails reading transmission dipstick-img_0049.jpg   reading transmission dipstick-img_0047.jpg
Old May 20, 2010 | 08:20 PM
pianofrk4's Avatar
i guess no one knows how to read this haha.
Old May 20, 2010 | 08:23 PM
elayman's Avatar
I believe the side that says HOT you look at the cross-hatched part (bottom is low and top is high) and the opposite side is the cold side and you look at the 2 notches (cold is if you haven't driven it around much I think) and I believe you check it with the engine running (at least that's what I've been doing)
Old May 20, 2010 | 08:28 PM
pianofrk4's Avatar
thanks for the response elayman I just checked my dipstick today while the engine was running after a 30 min. drive and it was waay past the cross-hatched high part... it was all the way towards the "rippled" part of the stick... is that bad u think?
Old May 20, 2010 | 08:30 PM
elayman's Avatar
check it again when it's cold on the cold side, if you have too much fluid it can be bad. Do you see any bubbles on the dipstick?
Old May 20, 2010 | 08:53 PM
pianofrk4's Avatar
no bubbles. What do bubbles mean? bad, i'm assuming? lol. I will check again tomorrow. Thanks man!
Old May 20, 2010 | 09:30 PM
elayman's Avatar
Ya if it smells burned or bubbling you need to change it. You can drain a bit out with the drain plug if you're too full and then add fluid as needed. When you add fluid change through the gears P R N D and back slowly a couple times to get the fluid leveled through out the tranny
Old May 21, 2010 | 08:34 AM
pianofrk4's Avatar
Thanks for the tips elayman. I plan on doing another drain and fill today as well as Sunday after my long trip to VT tomorrow. So 3 drain and fills total with about 100 mi. in between each.
Old May 21, 2010 | 10:39 AM
elayman's Avatar
why are you doing 3 drain and fills? lol okay though
Old May 21, 2010 | 11:50 AM
pianofrk4's Avatar
just to try to make it equivalent to a flush? LOL... i dont know..i am a n00b.. This is my first time doing self maintenance haha.
Old May 21, 2010 | 04:47 PM
kool_yaar's Avatar
^ if you dont mind spending time and money doing that, it can only help you get out as much old/dirty fluid as possible which is always nice.
Old May 25, 2010 | 07:28 PM
geronimomoe's Avatar
The 3 drain/refills is the way Honda recommends the ATF get "flushed" out of their system. Probably a bit safer and easier than unplugging the return from the radiator.
Old May 26, 2010 | 09:26 AM
pianofrk4's Avatar
just finished the drain and fills guys... now it's perfectly red I used 12.5 quarts total. And now i know why i keep getting weird readings on my dipstick. I had to keep the engine running while checking it, otherwise, the level will come all the way up to the ripple/wavy part of the stick. Check when engine is running and look at hot and cold sides. hot side needs to be in the meshed area and cold (opposite) side needs to be in between the notches. Thanks for the help ya'll!
Old Jan 23, 2016 | 02:53 PM
seanardy's Avatar
Please help
Please help, I just need a clarification so I dont overfill or underfill my transmission. When reading the transmission dipstick while the engine running at normal temp, the fluid should be in between the notches or it has to be above the notches in between the meshed area? I just doesnt make sense if the notches are for measuring cold when it says "HOT" in between the notches. I did my research and cant find the answer im looking to find. I really appreciate your help.
Old Jan 23, 2016 | 03:32 PM
vqsmile's Avatar
Tranny fluid levels are highly temperature dependent. The designations "hot" and "cold" are relative and may not yield very accurate readings, but it's still better than nothing. The dealership can talk to the computer to find the temperature of the tranny fluid to the degree and thus they can be very accurate.
http://www.nicoclub.com/FSM/G35/Sedan/2008/MA.pdf
(see page MA-20)
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
jbmw002
Sep 10, 2015 12:54 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
