If I bought my car used, should I reset my ECU?
Old Jul 23, 2010 | 04:05 PM
i3eezenotch's Avatar
Hey guys, I bought my car preowned and I was wondering if I should reset my ECU...I keep hearing things about this. If I should, how do I do it? Thanks!
Old Jul 23, 2010 | 05:44 PM
Austin713's Avatar
you can, but not nessicary... just unhook the battery wait a bit and reconnect..
Old Jul 23, 2010 | 06:00 PM
WhosRich's Avatar
Not necessary. It will learn to adjust to your style of driving anyway. But if you really want to, you can either disconnect the battery overnight or do the pedal reset procedure. Search for it.
Old Jul 23, 2010 | 06:32 PM
Thanks for the responses! Any advantage to resetting?
Old Jul 23, 2010 | 06:46 PM
mathnerd88's Avatar
I found that resetting my ECU made my car more preppy (i have a heavy foot)...My car after a while, would delay accelerating as I pressed my foot on the gas. After resetting the ECU, the engine was more responsive to my pedal pushing....
I believe my car did that because it wanted to be efficient saving gas...lol
Old Jul 23, 2010 | 06:55 PM
Hmm...how much of a gas efficiency decrease did you see?
Old Jul 23, 2010 | 07:30 PM
blnewt's Avatar
Did it turn the seats into Ralph Loren upholstery and have a Tommy Hilfiger first-aid kit? j/k
I think you meant "peppy"
Old Jul 23, 2010 | 10:38 PM
mathnerd88's Avatar
Maybe 1 or 2 MPG at most...but like I said, the car will automatically adjust the settings after a while...so if you want to keep that peppy feeling, you might need to reset the ECU maybe every couple of weeks? There's an easy method using the gas pedals.
Old Jul 26, 2010 | 11:35 AM
RaginCajun's Avatar
I just reset mine this weekend with a negative battery cable pull. I was getting this awful hesitation when I would first start moving. It was so bad the car felt like it was going to kill. I wanted the ecu to relearn my driving habits anyway so I did the reset. Ironically, the reset fixed my hesitation issue. I did lose some settings but nothing I couldn't fix. It's worth doing if you don't mind the hassle of setting a few things back up.
Old Jul 26, 2010 | 01:41 PM
What sort of things do you need to set up again?
Old Jul 26, 2010 | 02:54 PM
RaginCajun's Avatar
Let's see. I had to reset my window auto up and down, it lost my key to seat and steering wheel settings also. I also lost all my maintenance reminders and my mileage trip readouts. It's nothing that would keep me from doing it again. I also had to turn back on the steering wheel up option on exit and the sliding seat option.
Austin713's Avatar
radio presets.. mainly stuff in the headunit... your auto up down windows..
Old Aug 7, 2010 | 09:10 PM
nate704's Avatar
if i were you, i wouldn't do that.
maybe i'm just lazy after all.
Old Aug 7, 2010 | 09:34 PM
doeboy's Avatar
ummm no need to disconnect the battery. just use this method. So simple. It might take a few times to master it though.
Old Aug 8, 2010 | 07:34 PM
samsizzle's Avatar
how do you 'reset' the window up and down?? my auto windows will go down but not up help
