Question about Eibach springs for G35x
Since i'm a newbie, i wanna ask if it is necessary to install the pro-alignment kit with the springs. Please let me know. Thank you.
I just went with the Eibach springs and a camber kit on the rear, then went to a good alignment shop and they did a pretty good job. 2.5yrs later I'm on my second set of Potenzas up front from inner wear. If I was eating up front tires I would have gotten the front camber but the front wear is not bad at all. The rears wear perfectly normal.
Ooooppps jus realized you have the "X" so totally ignore my $.02
No kits on mine and tire wear has been fine for 9 months now.
Negative camber is not a tire eating culprit and it helps the handling quite a bit.
Just make sure you get the Toe set correctly and you'll be fine.
I honestly don't understand the thinking of those that drop and then get the camber exactly back to stock again. A little negative camber is your friend... embrace it... love it.
Like Aeson said camber is your friend and toe is the enemy. If you correct the toe to 0 and not factory you will be fine. Your tires will wear just as they would normally but from the inside. I'm on my iPhone right now but when I get home I'll post up a picture of my rear tires which I've driven on for 20,000 miles after lowering and they look like that are new.
kinetek
Aug 3, 2015 04:25 PM
