help please presets and setting wont save
Old Sep 16, 2010 | 10:16 PM
G420's Avatar
im having problems with the radio not saving the information like preset stations and bass/treble settings. anyone experience a problem like this? my car starts fine in the mornings so it cant be my battery
Old Sep 16, 2010 | 10:32 PM
TORETTO's Avatar
You're holding the preset buttons long enough until it beeps right?
I'm just asking so others can rule it out as a reason.
The treble/bass settings is something I haven't experienced. It's likely electrical. Because when you change your battery, you lose all settings. So something in the system must be resetting it.
Also state when it resets so others can help better. Does it reset after you turn off the car, meaning the system saves your presets while the car is running, then it resets it once the car has been turned off?
Or does it just not remember presets at all.
Old Sep 17, 2010 | 12:31 AM
G420's Avatar
yes im holding the button till it beeps and my presets only save when the car is on but when i turn the engine off the presets and bass/treble settings will be lost
Old Sep 17, 2010 | 12:34 AM
TORETTO's Avatar
If you don't get any answers here, I would take it to a shop. I'm guessing it's wiring gone bad, because I can't think of any other reason. Try a different section. There's the Audio/Video/Electronics section in the Tech Area forum.
Old Sep 17, 2010 | 01:24 AM
tg1234's Avatar
Is this a second generation G? I am asking because sometimes people post first gen G questions here too. If 1st that would explain somewhat since the head unit can go bad. Second generation seem like reliable. Do you have navi?
Old Sep 17, 2010 | 02:01 AM
Ditchdrinker's Avatar
Does your analog clock stay accurate? If it doesn't, it could suggest a battery problem.
Old Sep 20, 2010 | 09:48 AM
G420's Avatar
the clock so far has been correct and i have an 08 sedan
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SIKKI
Sep 16, 2015 01:14 AM
Machine Head
Sep 4, 2015 07:22 PM
Kicknshift
Sep 3, 2015 09:35 AM
