How to adjust headlights?
Old Sep 17, 2010 | 12:36 PM
G35_916's Avatar
So the car that I purchased happens to be a salvage G35. Got a great deal on it. One thing that I have noticed is that one headlight beam is higher and the other is a little lower. I heard they are automatic, but is there any adjustments manually?
Old Sep 17, 2010 | 12:47 PM
erklep's Avatar
search is your friend:
https://g35driver.com/forums/body-in...rojectors.html
Old Sep 17, 2010 | 05:32 PM
G35_916's Avatar
I actually did search in our specfic forum. So this same DIY will work for our 07 and up sedans?
Old Sep 17, 2010 | 05:55 PM
erklep's Avatar
same basic idea. the adjusters may not be in the same exact spots but similar
Old Sep 17, 2010 | 06:26 PM
Q8y_drifter's Avatar
the drivers side light SHOULD be lower than the passenger. It's to prevent blinding incoming traffic.
Old Sep 17, 2010 | 06:31 PM
dofu's Avatar
20 Year Member
^ Or to allow the flare to light up road signs which are usually on the right side in The States, while headlights flare towards the left in Japan for the signs.
Old Sep 17, 2010 | 07:48 PM
Borna's Avatar
I agree that the driver's side should be lower so I'm guessing your lights are adjusted just fine.
But if you do want to do any adjusting then it isn't like the DIY Eric posted, the 2nd gen sedan has 2 small white tabs inside the fenderliner (behind the front bumper) near the HID bulbs which can be twisted to raise/lower the beam.
Old Oct 13, 2010 | 12:51 PM
G35_916's Avatar
The right one is almost blinding from a certain distance. I'm pretty sure it needs to drop a little. Are those 2 tabs visible or do I have to remove a cover to see them? It was a little late when I was looking at the car and my damn bulb went out on my work light so I didn't really see them. Appreciate the help.
Old Oct 13, 2010 | 02:14 PM
kool_yaar's Avatar
Hope this helps better
Old Oct 14, 2010 | 11:05 PM
G35_916's Avatar
Originally Posted by kool_yaar
Thanks Paaji.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Fox843
Nov 7, 2015 05:43 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
