seafoam DIY?
Old Sep 29, 2010 | 12:57 PM
kool_yaar's Avatar
i would go with the brake booster line since it will reach the entire engine and is easy to locate and use.
Old Sep 29, 2010 | 09:14 PM
Ferrarimanic360's Avatar
so the brake booster cable WILL in fact allow the seafoam to reach the ENTIRE engine?
Old Sep 30, 2010 | 04:22 PM
upppp
Old Oct 2, 2010 | 01:02 PM
so i seafoamed the 2008 G35 yesterday using the main brake booster vacuum line... put 1/3 of the can in there and let it sit for about 30min before i started up the car. it smoked, but didnt smoke as much as my 2004 350z with the same mileage (and the 350z was properly maintained, using 91 gas only, and 95% highway driven). makes me wonder if the seafoam through the brake booster line only went to 1/2 of the engine on the G...
Old Oct 2, 2010 | 01:34 PM
efuseakay's Avatar
It's a 2008... I still don't get why you bothered with this.
Old Oct 2, 2010 | 03:24 PM
kool_yaar's Avatar
I am pretty certain it went to your entire engine since it goes through the plenum
Old Oct 4, 2010 | 11:02 PM
60k
87 gas since day one
Old Nov 6, 2010 | 08:59 PM
Dante's Avatar
^ ouch, I dont think I would ever run 87 on a G35
Old Nov 6, 2010 | 09:30 PM
_RR_'s Avatar
i wouldn't be surprised if most g35 owners ran 87
Old Nov 6, 2010 | 09:37 PM
Q8y_drifter's Avatar
93oct here. Not even 91. If I could run higher I would.
Old Nov 7, 2010 | 01:20 AM
kool_yaar's Avatar
93 all her life!
Old Nov 7, 2010 | 02:07 AM
Anyone tried half race gas mix in the tank? 93 + 100 ~ 96/97oct
Old Nov 7, 2010 | 02:18 PM
mathnerd88's Avatar
Originally Posted by celwin
Someone has to ask the stupid question. What is seafoam?
Seafoam is an Engine Cleaner that gets rid of deposits in your engine. It is usually done for cars that have high mileage. Someone before used Seafoam because he had rough engine idle and it fixed his problem. I would not recommend using seafoam on a car with lower mileages because it is a risky process and your car will give out error codes. Only use Seafoam at your own risk or with a professional car mechanic. Google is your friend.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
beto4632
Sep 23, 2015 04:28 PM
Jon81035
Sep 16, 2015 04:58 PM
