got bored so I added some GTR
I'm just gonna post the pics in bat's thread rather than making a new one (hope you don't mind bat). If I can do a DIY showing removal of the interior panels (I doubt my hand will fit behind there with the steering wheel at the lowest point), I'll do so.
US spec part number (looks to be same as GCC spec):
Switch, front:
Switch, side view, showing tab (there are two, on opposite sides) you need to overcome to remove the "guts":
Switch, side view, showing guts coming out (you can see the two tabs, L and R, in this pic):
Switch, rear view, showing guts removed (the clear white plastic membrane is reversed, should be other way):
Guts, exposed:
Guts, rear view, showing input for harness:
I removed the guts by pushing in two small, thin flat head screw drivers, one on each side of the tab holding the guts in. I then had an assistant remove the guts using a needle nose plier. You probably could do it yourself, but my friend was there to make it easier.
I'll remove the stock switch tomorrow, pics to follow.
Switch, front:
Guts, exposed:
