Bluetooth & Iphone4 trouble. Help!
Old Jan 4, 2011 | 09:04 PM
Aura01's Avatar
Hey everyone, so I just recently got a 2007 G35 sport non nav and am loving it. Only gripe I have is with my bluetooth. The phone pairs up with the factory unit with no problem, and can make and receive calls with the normal lag, but no matter what i do, there is no ringtone when i receive an incoming call. I deleted and repaired the devices several times and confirmed the ringtone setting in the car, but whenever a call comes in, neither my phone or the car stereo will ring, resulting in a lot of dropped calls. Has anyone else experienced this problem? Any help would be greatly appreciated!!
Old Jan 4, 2011 | 09:07 PM
terrycs's Avatar
The car should ring and give you the option to pick up. Is there a setting for auto answer?
Old Jan 4, 2011 | 09:11 PM
Aura01's Avatar
There isnt a setting for auto answer. What always happens is my phone goes to silent and i can see the incoming call on the phone display, and it usually takes quite awhile but then the car display will show an incoming call and I can either accept or reject it. Throughout this process, neither the phone or the car has any type of ringtone, and I cant figure it out
Old Jan 4, 2011 | 10:04 PM
Rwecked's Avatar
Did you check your settings? I believe there's something in there about letting the call ring through the car. I'll check when I get in the car tomorrow. So far I haven't had any issues.
Old Jan 4, 2011 | 10:33 PM
Aura01's Avatar
yeah i went into the settings and there was the option for ringtone or silent, so i assigned a ringtone to it, but it still doesnt work for me.
Old Jan 5, 2011 | 09:28 PM
asherwin's Avatar
I use an iPhone 4 w/ bluetooth without issues, but I have the nav package (so this likely doesn't help you.. except to let you know that it's probably not the phones fault).
Old Feb 4, 2011 | 12:04 AM
Jdinero's Avatar
its something with the iphone 4...I have an 07 G35S w/o nav too and it does the same thing...works fine with my blackberry and worked fine with my iphone 3GS but never rings with the 4.
Old Feb 8, 2011 | 01:50 AM
logicalswan's Avatar
Your issue may get resolved with a software upgrade. When I got my Droid X last year, it wouldn't work with my '07 G35 w/Nav. But when Android 2.2 was released and installed on my phone, the compatibility issue was resolved.
Old Feb 8, 2011 | 11:22 AM
G-BAT's Avatar
My iphone 4 paired and rings (nav) but how do I download my phonebook?
Old Feb 8, 2011 | 02:40 PM
CerveloR3-SL's Avatar
This is going to sound rude but...
Have you checked the volume setting on the car? You may just need to turn up the volume using the stereo volume ****...
I have never seen this situation. My I-phone 4 will make the car ring when its connected to blue tooth even when it is in Vibrate mode.
Good luck.
willdogs
Dec 8, 2015 11:32 AM
1Typhoon
Sep 25, 2015 08:45 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
JMSABO
Aug 4, 2015 11:58 AM
