Paint Chipping? Get a new Steering Wheel! but...
Old Jan 27, 2011 | 10:32 AM
jryuuu's Avatar
i bought my '08 earlier this month used.. when the dealer was prepping my car for resale, they swapped out the door trim and steering wheel bc of these issues..
however, the shifter in the center is pretty scratched up on the middle metal portion.. has anyone had luck getting that replaced under warranty?
Old Jan 27, 2011 | 10:45 AM
Rutland's Avatar
Quick update...
So, I brought it in to get the cruise control fixed and of course, that had nothing to do with the new steering wheel being installed. Really? My cruise control (operated on the steering wheel) just happened to go out right after they worked on my steering wheel....and the two aren't related? Sure Infiniti of Marietta, Georgia. Only the third time in the past three times I've heard a ridiculous reason come out of your month.
Old Jan 27, 2011 | 11:14 AM
r3plicant's Avatar
I didn't get mine replaced, but I did use masking tape and steel wool and just took the coating off. If you go this route, just make sure to only go in one direction when using the steel wool. I'll try to get a picture posted of my end result.
Old Jan 27, 2011 | 11:26 AM
jryuuu's Avatar
i'd really appreciate that. i may go that route cause it's driving me nuts every time i get inside my car.. such an eye sore..
Old Jan 27, 2011 | 09:38 PM
RealMothaEffinG's Avatar
same here man, used 2008 also with scratches on the shift ****. So Uglyyy. Also waiting for pics of the sanded down ****
Old Jan 28, 2011 | 02:59 PM
r3plicant's Avatar
Here's what it looks like after hitting it with steel wool. I'm sure you could polish it up a bit for more of a finished look. The person who owned my car before me either wore a ton of jewelry or had dragonlady nails or both. I'm still getting scratches off the outside door handle.
Old Jan 28, 2011 | 04:37 PM
anrman's Avatar
They had Dr. Vinyl repair mine. You can't tell there was a problem but not sure how long it will last.
Old Mar 25, 2011 | 03:18 AM
scorpkev's Avatar
G35 Sedan RWD
Originally Posted by Kube929
My steering wheel was put on crooked too! I went back and they said that it looked fine. That's because they didn't drive it and it's only a few degrees off. But when you drive it every day it will really **** you off. I'm taking James' advice and trying to align it myself.
hey, for those of you who got a new steering wheel, how did you fix the alignment yourself?
because I just got mine car back and it is off very slightly but still, car will pull to the left if i put the steering wheel straight...it is annoying. damn infiniti tech..
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
shepscrook
Aug 13, 2015 11:37 PM
