Paint Chipping? Get a new Steering Wheel! but...
Old Jan 18, 2011 | 02:06 PM
Rutland's Avatar
make sure they hook the cruise control back up.
I found out they screwed that one up on my 5 hour drive to Charlotte this weekend. True, things could be worse, but that's an insanely easy drive with cruise control. Without it...I was just happy it was over.
Old Jan 18, 2011 | 03:47 PM
r3plicant's Avatar
Just had mine replaced. I'll check my cc on my way home. Thanks for the heads up.
Old Jan 18, 2011 | 11:57 PM
Sjshore75's Avatar
How are you getting them to replace it. They say it's chipping because of ring marks not a defect in paint
Old Jan 19, 2011 | 02:06 AM
tg1234's Avatar
Ask them if that is the case why did infiniti switched to harder plastic in mid 08. My 07 was bad like that and I never had rings on my finger in my life. Most people have issue with it.
Old Jan 19, 2011 | 09:31 AM
r3plicant's Avatar
Well they are using harder plastic, and correct me if I'm wrong, but I heard they switched vendors on the '09 + models because of this issue.
And on top of all of that, you buy an Infiniti and pay a premium price for it, but they expect you to not wear jewelery in their cars because it causes damage?
Old Jan 20, 2011 | 01:50 AM
james0076ss's Avatar
Had my steering wheel replaced by the dealership under warranty, but they aligned it incorrectly and was tilted to the left, went back 2 times and hey still couldn't get it right, even after they performed an wheel alignment. I just took the steering wheel off and aligned it myself.
Old Jan 20, 2011 | 02:32 AM
bluedevils95's Avatar
I guess i need to get mine replace sometime soon. But i am going to do something different if i can work it out w/ the dealers. (top secret)
Old Jan 22, 2011 | 12:06 PM
ced357's Avatar
So, will my dealer replace the wheel under warranty. Mine is starting to chip badly.
Old Jan 22, 2011 | 12:15 PM
Yes they will.
Old Jan 24, 2011 | 06:40 PM
Kube929's Avatar
My steering wheel was put on crooked too! I went back and they said that it looked fine. That's because they didn't drive it and it's only a few degrees off. But when you drive it every day it will really **** you off. I'm taking James' advice and trying to align it myself.
Old Jan 25, 2011 | 10:06 AM
herkster's Avatar
if mine is just slight on the left side where the previous owner had a ring on their hand, will they still warranty?
Old Jan 25, 2011 | 11:27 AM
speed817's Avatar
i noticed my paint was chipping under the volume controls. how much was it to get it replaced?
Old Jan 25, 2011 | 12:09 PM
biggz786786's Avatar
my bumper to bumper warranty is expired, will i still be able to get it replaced?
Old Jan 25, 2011 | 06:58 PM
rahulpatel's Avatar
Talking
I live in Dallas and took my 08 G35 in on Friday and go it back today. They replaced the:
Steering Wheel as the plastic or whatever would peel off by barely even nicking it with my nail.
Drivers Side "Window Trim" on the door because it would scratch so easily.
All Window Rubber Trim because the drivers side front and rear was looking like it was melting or disintegrating.
Dash Trim because it was lifting up due to a manufacturing defect.
Fixed the Right knee trim panel on drivers side because the clip or whatever behind it wasn't holding it down.
I wasn't asked one question by the service adviser, he just wrote down all the things that needed to be looked at and had all the work done without and question or comment that it could not be replaced.
Old Jan 27, 2011 | 10:30 AM
jryuuu's Avatar
i bought my '08 earlier this month used.. when the dealer was prepping my car for resale, they swapped out the door trim and steering wheel bc of these issues..
however, the shifter in the center is pretty scratched up on the middle metal portion.. has anyone had luck getting that replaced under warranty?
