Wired for satellite or not?
Old Jan 20, 2011 | 01:38 AM
Brian-g35s's Avatar
So I have 2007 G35 Sport Sedan. Manual, Premium package.
I've been trying to determine if I have the wireing harness which I believe would be in the trunk. I've done some searching and seen conflicting posts. Some say the harness is there in all 07 G35. Others - only if you have a "SAT" button - which I do not have. How can i find out for sure it's there without ripping out the trunk liner.
are their other options to putting in a SAT radio retaining the display and steering wheel controls without using the infiniti unit?
thanks,
BB
Old Jan 20, 2011 | 03:35 AM
mannyh316's Avatar
If I am not mistaken all 05 and up G's are prewiired. I just added xm radio to my coupe I don't have the SAT button. Your connection should be in the trunk Search or google it there is a DYI somewere
Old Jan 20, 2011 | 10:40 AM
txdave13's Avatar
If you've got the premium package, I'd bet dollars to doughnuts that you've got already got sat capability. The "Radio am/fm" button will toggle through the selections.
That is the only button I have and I have satellite. Check your manual for more detail.
Old Jan 20, 2011 | 12:01 PM
Brian-g35s's Avatar
well the manual being written to cover most if not all variants of the G35 - is unclear. And again - most people "believe" it's there but I was wondering if there's a way to be sure.
Also, anyone else install something other then Infiniti's SAT radio option?
Old Jan 20, 2011 | 03:00 PM
kool_yaar's Avatar
It is prewired from what iv seen on here, i "believe" the wiring is under the drivers seat, a little snooping around in that area should get you a definite answer for sure.
Old Jan 20, 2011 | 03:03 PM
kool_yaar's Avatar
Just did a quick simple search and found a definite answer here. The car is prewired 100% and the module is in the trunk, a diy with Pics is within the link! G/L
Old Jan 20, 2011 | 03:09 PM
filipinowise's Avatar
I agree, I don't have a "SAT" Button either. How ever i was able to preview xm channels. I was playing setting and going through all the and found my Radio ID number.
Old Jan 20, 2011 | 03:29 PM
msu2001la's Avatar
My 07 G35x has no SAT button but definitely has the wiring harness in the trunk. It's not hard to find if you look.
I haven't hooked anything up to it, but people on here say it's just a matter of plugging in the module.
Old Jan 20, 2011 | 05:26 PM
Brian-g35s's Avatar
thanks guys. I have searched and found several DIY postings. I was just curious if there was another way to verify because when googled it originally - I found a post where the guy said he didn't have the harness. maybe he just didn't find it. who knows.
Someone told me there was a solution from iSimple (?) that was just as good but cheaper - anyone using that or something similar? just curious - I've not heard of it.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
