Torque Settings
Old Feb 3, 2011 | 01:12 PM
joesmithf1's Avatar
Torque Settings
hi u guys, is there is thread somewhere that list all torque settings? i can't find any. i am planning to DIY on the lowering and wanted to make sure the torque will be set correctly when i put the pieces back.
thanks!
Old Feb 3, 2011 | 01:23 PM
4DGS's Avatar
Just bang em on
Good thing about suspension parts is they are built tough so they can handle high torque and you can always use a breaker to get them back off.
I doubt you're going to find a sheet with specs on it for every part of the suspension and in all the suspension I've ever done, I've never torqued anything to spec.
Old Feb 3, 2011 | 01:58 PM
soundmike's Avatar
^ you could do that, but there's a reason various bolts need to be torqued down to certain values. Too tight and they take on too much pressure at the limits and could break off. Too loose and, well, they'll eventually micro-vibrate themselves off. YMMV, of course, but it doesn't take much to follow the #'s, and I like to play it safe.
OP, you can refer to the FSM. It contains pretty much every single value you need.
You can download it from my site.
I also have direct info on the damper/spring area here.
Old Feb 3, 2011 | 02:07 PM
joesmithf1's Avatar
awesome! i really appreciat it!
Old Feb 3, 2011 | 02:11 PM
4DGS's Avatar
I've done 40ish suspension swaps, never torqued anything to spec and never had anything loosen or snap.
Old Feb 3, 2011 | 04:48 PM
bluedevils95's Avatar
Since i don't have torque wrench i just tighten everything snug tight. Worked for me so far and never had a problem.
Old Feb 3, 2011 | 04:53 PM
CandlestickPark's Avatar
ill Sedan
You must have the magic touch Blain.
Old Feb 3, 2011 | 06:39 PM
rpm&my_G35's Avatar
Here are the suspension sheets from the 2007 Sedan manual.
2WD-fsu.pdf, AWD-fsu.pdf, rsu.pdf
mbe32
Interior
Oct 1, 2015 09:47 AM
mattdg35
Sep 14, 2015 11:28 AM
twentyeggs
Sep 11, 2015 03:58 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
