Transmission oil change effect warranty?
Old Feb 17, 2011 | 01:36 AM
3lpaisa's Avatar
Question Transmission oil change effect warranty?
Ol so if I change my own oil on my tranny would it effect the engine n trans warranty??
Old Feb 17, 2011 | 11:04 AM
kool_yaar's Avatar
there are no gaurantees, its all about how u deal with them, as long as you get OEM oil and save the receipt and note down the mileage then you should be fine.
Old Feb 17, 2011 | 02:32 PM
blnewt's Avatar
If the tranny blows up the day after you DIY there may be some questions
Old Feb 17, 2011 | 05:06 PM
kool_yaar's Avatar
As long as you have your receipts you dont have much to worry about, since IF anything like this ever happens its on the dealer to prove that something you didi might have caused it. However if you are using OEM fluids then there is nothing they can say about it.
So just get OEM if you are worried about warranty and you'll be fine.
Old Feb 17, 2011 | 07:59 PM
treacherous's Avatar
20 Year Member
G35x
There is a TSB about denying claims if OEM isn't used.
I believe it is ---> ITB08-022a
Old Feb 18, 2011 | 04:21 PM
kool_yaar's Avatar
^ very nice find treacherous as usual, that should put an end to all the presumptions of whether OEM should be used or AM...
ITB08-022a
Description: 2004 TO PRESENT ALL INFINITI MODELS; SPECIAL AUTOMATIC TRANSMISSION FLUID REQUIREMENT
If Warranty repairs are being done on a transmission listed in the chart below, the listed fluid must be used. A claim to Infiniti for warranty, service contract, or goodwill repairs to the transmissions listed below may be denied if Genuine Nissan ATF Fluid is not used as specified by the part # in this bulletin.
Old Apr 17, 2011 | 08:58 AM
ampsucker's Avatar
moss magnuson allows the use of any aftermarket parts that meet specification without voiding the warranty.
read the manual. if it specs 90w gl5 lube, any will work. if it specifies infiniti OEM 90w gl5, only that will work (for warranty issues).
toyota does this with ATF fluid as well.
Old Apr 17, 2011 | 03:30 PM
kool_yaar's Avatar
^ thats true for when they dont specifically state it like amp said and infiniti does say to use only their ATF so... "A claim to Infiniti for warranty, service contract, or goodwill repairs to the transmissions listed below may be denied if Genuine Nissan ATF Fluid is not used as specified by the part # in this bulletin." thats enough legal backing for them to deny your claim if needed.
Old Apr 17, 2011 | 03:32 PM
thescreensavers's Avatar
Mr.202?
Dont be stupid and try to be smart, use OEM Fluid.
If you do it properly you will not void warranty.
11bEMT
May 27, 2022 03:13 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
ClwMike
Jul 23, 2015 12:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
