08 g35 sedan navigation reset or calibration
Old Feb 21, 2011 | 08:02 PM
Aaron's35's Avatar
If anyone knows how to reset the navigation, can you please tell me I did the bypass thing and everything is fine except the map is not calibrated now. For example while using it now, it's basiclly just moving across the screen and constantly saying turn here etc although I'm not able to.
Old Feb 21, 2011 | 08:11 PM
kool_yaar's Avatar
Well for one you are not allowed to discuss nav bypass or anything related to that as its illegal in most states and is a forum rule... btw u have a PM
Old Feb 21, 2011 | 08:25 PM
Aaron's35's Avatar
I'm not asking for directions for that, I'm just asking about resetting the actual unit itself.
Do I have what sorry man i'm old lol?
Old Feb 21, 2011 | 08:42 PM
kool_yaar's Avatar
no big deal hopefully it solves your problem and there is no real way of resetting the nav other than switching the car off and back on form what i know.
Old Feb 22, 2011 | 12:14 AM
treacherous's Avatar
20 Year Member
G35x
Here is an old thread I posted years ago to get into Nav Diagnostics:
https://g35driver.com/forums/1701912-post1.html
Old Feb 22, 2011 | 01:19 AM
SMOOTHDLR's Avatar
If you installed a switch make sure when you want to use the navigation the switch is on, and when you want to use the other function (thing we are not allowed to discuss) the switch is off.
Old Feb 22, 2011 | 10:47 AM
kool_yaar's Avatar
ya he already tried that... im thinking something t do with the "install"
Old Feb 22, 2011 | 11:10 AM
Mrpeeng's Avatar
try a hard reset? meaning pull the battery for a few mins.
Old Feb 22, 2011 | 12:25 PM
preston8o8's Avatar
wow thats weird
Old Feb 22, 2011 | 07:49 PM
Aaron's35's Avatar
I've tried doing the nav diagnostic everything lights up but other than that nothing, I hit the info button and it said that it's out of range so my next step would be figuring that out.
Old Feb 22, 2011 | 08:17 PM
20 Year Member
G35x
What about this?
1. Start the engine.
2. Turn the audio system OFF.
3. While pushing the “SETTING” button, turn the volume control dial clockwise or counterclockwise for 40 clicks or more. (When the self-diagnosis mode is started, a short beep will be heard.) • Shifting from current screen to previous screen is performed
by pushing “BACK” button.
4. The trouble diagnosis initial screen is displayed, and then the items of “Self Diagnosis” and “Confirmation/Adjustment” can be selected.
Old Feb 22, 2011 | 08:19 PM
Aaron's35's Avatar
Okay thanks man, I will try it now
Old Feb 22, 2011 | 08:20 PM
kool_yaar's Avatar
Well you see the problem has occurred after his "mod" and from what i gathered the nav worked gr8 b4 this, so such resets and diagnoses are not going to help IMO, i have suggested he recheck his mod procedure cause from what i have seen its a common issue when the mod is not done a 100% right, a simple recheck of the switch connection might resolve the problem.
Old Feb 22, 2011 | 08:22 PM
20 Year Member
G35x
Maybe the initialize settings option?
Here are the rest of the diagnostic screens.
Old Feb 22, 2011 | 08:48 PM
Aaron's35's Avatar
kool yaar, i check out the message you sent me in doing so i can say that i've did everything right. Everything else with the gps works just fine, places near by, etc i really do think it's just the gps signal
