Raccoon vs. G
Old Feb 28, 2011 | 12:26 PM
AesonVirus's Avatar
This was a good thread too...
https://g35driver.com/forums/lounge-...front-you.html
Old Feb 28, 2011 | 12:41 PM
ChinkyChoy's Avatar
Double KO?
Old Feb 28, 2011 | 07:05 PM
UCIMAplaya2's Avatar
I hit one a couple weeks ago that was already dead in the middle of the road. He was really big and my car is lowered a little. I didnt see it until the car in front of me (ford escape) went over it and then it dawned on me that I wouldn't be able to clear it. Couldn't do anything about it and just hit it dead center. It dragged a bit on the front bumper, then the trans cross-member and finally the rearend. No damage but it sure seemed like it should have done something. Sorry you werent so lucky
Old Feb 28, 2011 | 07:24 PM
SkylineGTR2789's Avatar
lmao same exact thing happened to me the other night, i pulled over to look for damage after smelling fried burgers coming from the car, i think it was the blood on the exhaust
Old Mar 1, 2011 | 08:38 AM
N80's Avatar
N80
I've based how much I can lower my car on the height of a normal adult dead possum.
Old Mar 1, 2011 | 08:43 AM
AesonVirus's Avatar
Measuring what?
If you look under the X, clearance is already so little that I doubt you could clear a dead possum right now.
Your bumper may clear, but I don't know about the belly (under the engine/tranny)
With my Eibachs, I can't even stick my fist under there anymore.
Old Mar 1, 2011 | 09:03 AM
N80's Avatar
N80
The X clears a dead possum with no problem. The coupe cleared on last week but it looked small....or maybe a little flattened.
But you're right, bottom line is I'm not lowering my coupe at all. No coilovers. Next suspension mod will be Tokico D-spec shocks/struts with no change in ride height. Lower would be nice...until I needed to drive it.
Old Mar 6, 2011 | 04:05 AM
rbayne's Avatar
Man, I had no idea about the washer res.. I am gonna get on it tomorrow and see if I can fix her. I will post some pics once done. Thanks for the info guys!
Old Mar 6, 2011 | 07:15 AM
gtbigup01's Avatar
Looks like the only one lost was you considering you couldn't find the little F***er. Well it's not too bad so hopefully you get that fixed easily.
Old Mar 6, 2011 | 08:54 AM
preston8o8's Avatar
that should be a easy fixed when i use to have my lexus LS i got a raccoon stuck under my car and still alive and when i tried to get close it would start making this crazy sounds and then i try to poke it with a stick but it kept attacking the stick so finally since i had airbags on my ls i hop on the freeway and rode real low and finally he fell out from under and someone else ran over him lol
Old Mar 6, 2011 | 02:54 PM
RedBaronK's Avatar
Ummm what???? Lol
Old Mar 9, 2011 | 01:11 AM
rbayne's Avatar
Took it to the body shop today for a quick quote....FU@K that, they want over 500 to fix it...I am def gonna try this myself, just gotta find the time
Old Mar 9, 2011 | 01:36 AM
vqsmile's Avatar
Patience and a heat gun will do wonders for it. If it doesn't work, you can always go back to having it fixed at a shop.
Jiggerjuice
Aug 31, 2015 11:49 AM
Biggzy
Jul 21, 2004 07:26 PM
Biggzy
Jul 20, 2004 10:57 PM
belerin
Oct 31, 2003 06:13 AM
