Raccoon vs. G
Old Feb 27, 2011 | 01:16 PM
rbayne's Avatar
Raccoon vs. G
Old Feb 27, 2011 | 01:24 PM
Hi-TechG35's Avatar
Pics of the coon?
Old Feb 27, 2011 | 01:26 PM
rbayne's Avatar
Couldn't find his little azz, was big though!
Old Feb 27, 2011 | 01:59 PM
E-Ticket Ride's Avatar
Time for a sport bumper
Old Feb 27, 2011 | 03:08 PM
mishmosh's Avatar
It looks like you can just pop that out and call it a day. Use a heat gun if you need some help.
Old Feb 27, 2011 | 03:14 PM
AesonVirus's Avatar
Boy, this brings back memories...
https://g35driver.com/forums/lounge-...it-coyote.html
Old Feb 27, 2011 | 03:24 PM
rbayne's Avatar
Yes I was gonna give it a try next weekend. Do you think I would have to remove the bumper?
Old Feb 27, 2011 | 04:42 PM
LakeShore_Slate's Avatar
I would recommend a friend to tag along with you, would help a lot. Just use painter's tape to measure and remeasure before you drill.
Old Feb 27, 2011 | 04:45 PM
rpm&my_G35's Avatar
it would probably help so you can push it out from the inside. I don't think it's going to look right even if you get it to pop out but its definitely worth a try.
Old Feb 27, 2011 | 06:39 PM
RedBaronK's Avatar
I had the exact same dent on my bumper.... u can push it out from underneath without lifting the car up. Losen some bolts holding the underbody in place, get ur hands in there and use a heat gun in it. Be very careful, my damned paint chipped during the process and needed to get repainted. Being that ur car is black, even if it chips a little it will be harder to spot than what happened on mine. Do it asap, before the bumper cover retains the shape.
Old Feb 27, 2011 | 08:03 PM
bluedevils95's Avatar
that sucks! Hope you get it fixed soon.
Old Feb 27, 2011 | 08:06 PM
mishmosh's Avatar
I would not remove the bumper. That is a pain. As stated above, try to pop it out from underneath. Try heating it up before you pop it and there is less chance paint will flake off. As long as you get the basic shape back, I wouldn't worry about crease marks--I don't think anyone will notice. Post up some pics after you fix it!
Check out this:
Old Feb 28, 2011 | 09:45 AM
djfarhan's Avatar
ouch, hope that is easily fixable
Old Feb 28, 2011 | 11:29 AM
N80's Avatar
N80
Mt daughter hit a cat. Roughly the same place. It also cracked the wiper fluid box, which in right behind the right front bumper. The wheel well liner was also gone. In addition to the dent, which looked just like the OP's, the plastic had a tear in it and the paint was crazed and cracked.
No way to fix it properly myself. The total bill (at a very high quality and respectable body shop) was $950. This included a brand new Infiniti bumper and replacement parts (the wiper fluid pump was also destroyed). Did not include blending. He let me look at it before blending and it was close enough.
Bottom line, inspect well, especially behind the bumper.
Old Feb 28, 2011 | 12:24 PM
AesonVirus's Avatar
/\ Ditto... I didn't know I blew out the washer res until I got home and tried refilling it just to see it pouring out al over the garage floor.
There's a lot going on behind that corner so do check it out well.
