plz HELP.. VDC problem
hi all
i have infiniti G35 2008 and it had problem in VDC.
the problem is i cant know when the vdc working or not, becuase there is no mark in the guage, i think it dose not working at all..
please if any one know this issud explain to me the following:
1- is it a big problem ?
2- is it depends on software programming or replacment a new part?
3- how much will cost me in USD
Al,
Look up the dashboard definitions in your owner's manual. It will show you where the VDC light should be (left of center). If you're light isn't on, there probably isn't a VDC issue.
Why do you think you have a problem?
J
J
thx u all..
@ jcrayamsterdam: actually i dont have onwer's manual. but i believe VDC should light up on my guage when it turn-off.
@ samsizzle : i have no warranty bcz i bought it used car
@ kool yaar: i am sure i have VDC, bcz there is push-button at the left side of my stearing..
looking for ur soon apply
Really? I thought it was a standard option
^ ooops my bad!! i was a bit "dazed" when i replied last night
For some reason i i registered VDC(standard) as VLSD(optional) in my mind, thats why you should not go online when ur not a 100% "focused"
But if you dont see the light "VDC OFF" when you turn OFF the vdc it could be an issue with the bulb imo cause if there was an issue with the VDC then i would think it would actually come ON to tell you that its not active IMO, you can go to a big empty lot and floor the car for just a second(at your own risk) and see if you feel the car cut the rpm to avoid excessive wheel slip, if you get a big burnout then the VDC is NOT working else if you hear a chirp and car takes off it should be working fine.
But definitely get it checked out by a certified mechanic or dealer asap.
thx alot kool yaar and hope u get well soon
i checked the fuse box which is beside the battery and i found some fuses are missed
1- ETS fuse
2- 4WAS 40A fuse
3- 4WAS 20A fuse
4- H/L WASH fuse
can i replace new fuse from spare fuses are stored in the passenger compartment fuse box????
looking forward ur soon advice
1- ETS fuse
2- 4WAS 40A fuse
3- 4WAS 20A fuse
4- H/L WASH fuse
im recovering well
... now 2,3 and 4 are something totally different and wont help since i doubt you have the 4 wheel active steering option(4WAS) or the headlight washer(H/L WASH) and ETS is Electronic Torque Split for AWD, have u checked every other fuse? maybe some blown fuse somewhere, check the fuse box on the driver side floor area to the left of your brake.
Thebaws11
Jul 2, 2021 11:36 AM
