cracked skid plate...help
Old Mar 7, 2011 | 02:10 PM
Eug96's Avatar
hey guys,
after a rough winter i noticed the front skid plate along the under body is cracked and some parts will scrape along the ground when going over minor bumps. Kind of a loud plastic scraping on the ground sort of sound. should I have the skid plate replaced or just try to rip off the excess plastic hanging although it seems pretty tough to get under the car to do so
Old Mar 7, 2011 | 02:21 PM
kennymo's Avatar
are you talking about the plastic under carriage cover?
and just a jack or some ramps and get under there
Old Mar 7, 2011 | 03:00 PM
kool_yaar's Avatar
^whs, if somehow the plastic under cover is messed up then you should replace it cause it helps keep the mess and water out and is essential for the cars aerodynamics as well, if u wanna take it out you should jack it up and unbolt the remaining pieces cause its held in place with sturdy bolts and wont be easy to "rip off" imo
Old Mar 7, 2011 | 03:24 PM
CerveloR3-SL's Avatar
Unless it is torn is specific places.. you may just need some more screws and attach it back to the bottom of the car.
DRG35R
Jan 31, 2016 07:14 AM
Batfinity
Lights
Sep 27, 2015 12:29 AM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
