Is there a proper way to go from N back to D on the highway?
Old Mar 4, 2011 | 08:50 PM
Anton_Chigurh's Avatar
I need to put my car in N when on highway to eliminate a problems i am having with vibration. I need to do this at 75 MPH...I know it wont hurt going from D to N on at these speeds but can i go back to D without hurting the transmission? Should i try and match RPM's then slip back to D?
Old Mar 4, 2011 | 08:57 PM
mikeb2's Avatar
Just drop it in. You'll be fine. It's not a biggie.
Mike
Old Mar 4, 2011 | 09:16 PM
Mike
So no issue with doing this? Should i expect a loud thud? lol
Old Mar 4, 2011 | 09:19 PM
Seal89's Avatar
i think you can do it if you do not press on the gas
Old Mar 4, 2011 | 09:53 PM
AesonVirus's Avatar
Take your foot off of the gas and let the RPMs settle, and it'll take to D with no issues at all.
Old Mar 4, 2011 | 09:58 PM
perfect..thanks
Old Mar 5, 2011 | 10:39 AM
RemmyZero's Avatar
separate question but do you know what's causing your vibration?
Old Mar 5, 2011 | 01:29 PM
RedBaronK's Avatar
Btw... are u guys talking about D mode in auto or 6mt?
Old Mar 5, 2011 | 01:32 PM
thescreensavers's Avatar
Mr.202?
^ there is no "D" mode in 6mt
D stands for Drive in Auto
And yea just let go of the gas and slip it in.
Old Mar 5, 2011 | 02:04 PM
agedog2gt's Avatar
Should fall in no problem. might hike up the rpms a bit??
Old Mar 5, 2011 | 03:33 PM
Songle6MT's Avatar
Why are you having to put it in N on the highway, what vibration is causing you to have to do that? It shouldn't be necessary
Old Mar 5, 2011 | 04:15 PM
I need to see if the vibration is engine/trans related
Here is the saga:
https://g35driver.com/forums/v36-bra...d-highway.html
Old Mar 7, 2011 | 06:41 AM
RemmyZero's Avatar
im gonna read through your post because my ex girlfriend is having the same problem and it's really bad (she has a 2003 eclipse). i'm down to tie rods or the tranny, and i'd hate to have to replace the tranny.
Old Mar 7, 2011 | 11:36 AM
Austin713's Avatar
if its engine trans related you would still get vibration in neutral. everything inside the transmission is still moving around when your in neutral anyway.
Old Mar 7, 2011 | 05:25 PM
^^^ While i tend to agree with this, when i put it in N RPM's dropped down to about 1000 and the vibration was still occurring which usually only occurs in the 3000 range on the highway, not in the 1000 range when driving around town, so i believe i have ruled out the engine as well as trans.
I know the trans would still be moving..but would it be moving to the extend of driving at 75MPH at 3000 RPM's?...because when i went back to D from N, you could feel the trans engage again and RPM's went right back up to 3000
Kng0fHrts
Sep 15, 2015 05:40 PM
rping
Jul 26, 2015 09:53 PM
Texasscout
Jul 24, 2015 03:43 PM
apintojr
Jul 23, 2015 10:52 AM
