Tach illumination flashing
Cluster backlight DIY
I have the same issue on my 2008 G35x. Mine actually is off at all times.
I was going to attempt a fix myself, under the impression that the instrument panel could be removed without taking apart the entire dash. My thoughts on the procedure would be to remove plastic clam shell and controls from steering stem and unfasten the plastic around the cluster and slip it back and over steering stem.
Has anyone actually done this to confirm?
Same issue on my 08 Journey...
I had some serious issues after I had a shop program a third key. Long story short the car would not even start or recognize the keys and it was in the shop for months until they actually figured out what was going on. The shops insurence paid for repairs and a loaner car. After I picked up the car and signed the release I started to have the same thing right around 6 and 7. Then about a day later it started on 4 and 5.
I called the shop and that fixed the car and they said they never removed the cluster so it's nothing they did. And where I have signed a release the other shop's insurence is out of the question.
So I'm looking for a DIY solution. I've got a baby on the way and can't afford the dealership anyway...
Any update on a successful attempt at replacing the bad LED bulbs?
You cannot just replace LED. I have same issue, light are flickering around 2, 4 and 7 on mine g35.. LED diode will not burn per say unless you supply too my voltage to it. It is a circuit that supplies LED with power that is getting bad. This is same as if you have bad LED ligt at home, you cannot replace LED diode by itself, but eniter bulb, that include circuit that powers LED.
After talking to my my dealer i found out the circuit is not seperate board that is attached to instrument cluster, that someone can unsolder and solder new one. Thus you either need to know which part or circute is bad and replace that specific part or replace entire cluster. Since multi lights are going off (at least in my case it is multiple lights) then hunting down which resistor or capacitor is bad and replacing only those that are busted makes no sense. No one can guaranty that those that are good now will be working fine in the future,they may get busted next week. And seen that I have issue with three lights right now I am sure there will be more getting bad. So the only thing is to replace the whole circuit board on the instrument cluster (which is unfortunate as that means I am in agreement with the dealer).
Anyways, my dealer said it cost ~$800 to replace the circuit board with the instrument cluster. I am not going to do it now, but once the issue spreads to speedometer where I potential could not see my speed at night, then I will look into replacing the instrument cluster.
BTW, you can buy the instrument cluster online for about $300 and in IP section of g35/37 service manual (http://pdf.textfiles.com/manuals/AUT...SAN/g37/ip.pdf) you can see how to disassemble the cluster. It is quite a bit of work. However if there is anyone that has done it, I would love to hear his/hers experience.
No. From what I have researched it is not an easy DIY repair. FYI, my fuel gauge LEDs have gone out too, but remember that the center 7" info display also shows miles to empty if you choose to show that info. Just keep pressing the status button to show it. That is what I use to be informed on fuel level. There are used instrument panels for $160 on ebay. Also, there are outfits that rebuild the instrument panels but you have to pull it out, send it to them, and wait for the rebuild to be returned. See link here:
https://www.ebay.com/itm/05-06-07-08...BVEaNM&vxp=mtr
Did you end up getting it fixed?
I have this same problem and I am out of warranty. Auto shop near me said they would replace the whole cluster for $1100...As of now the 6-7 on the tach is the only thing out. Is it likely the whole thing will go out soon or should I not worry?
Has anyone gotten this fixed??
Bought a 2008 g35xS like 3 months ago 98k miles on it now and have gotten the annoying led bulb behind 5-7k on tach is flashing. Does it get worse and is it expensive to fix? Thanks in advance
Yes. It will get worse. Starts with Tachometer, then expands to other areas of tach, then entire fuel gauge, entire temp gauge, and clock. From what I hear, dealers want $1100 and up for the repair. There are places on ebay that will repair it for $100 and up but you have to pull it from the dash and send it to them. I hear it is not an easy and quick DIY for removing the instrument cluster. I still have not repaired mine since I can still see the needle in the gauges.
https://www.ebay.com/itm/REPAIR-SERV...AAAOSwg~9cby5K
Not sure about odometer reprogramming, but found this thread on the question:
https://g35driver.com/forums/g35-cou...placement.html
