Using different gas stations
Old Apr 4, 2011 | 09:28 PM
blnewt's Avatar
Originally Posted by jaeisber
thats $1.40 per LITER and $5.299 per GALLON.
3.79 Liters per gallon:
3.79*1.40 = $5.306
The US had really cheap gas compared to the rest of the world.
fyp
Old Apr 4, 2011 | 09:30 PM
jaeisber's Avatar
Haha touche
Old Apr 4, 2011 | 10:28 PM
Da_KiiD_cT's Avatar
Originally Posted by blnewt
fyp
lmao...good one
Old Apr 5, 2011 | 09:07 PM
T.Paz's Avatar
I only use top tier gas. In order of preference...Shell, Mobil and Phillips 66 in my area. Check out http://www.toptiergas.com/retailers.html for the entire list of retailers...
Old Apr 26, 2011 | 01:03 AM
anderson1137's Avatar
So recently, I've been using Shell gas because i wanted to try the nitrogen enriched gasoline. I've used about 2-3 tanks now, and i must say I can feel there is a difference between the Shell gas and the ARCO gas i used previously. Shell gas is ALOT smoother than ARCO. When my car is going on low rev it is a little jumpy (nothing really significant). now i've been using the Shell gas for the past month, that little jumpy feel is gone! everything is so smooth! so afterall, I guess paying 10 cents more for premium does make a difference. GO SHELL!!
Old Apr 26, 2011 | 07:41 AM
g35xdriver's Avatar
g35x
i didn't have good luck w/Shell premium, mpg went down 1-2. Mobil/Exxon was my benchmark.
lately been using 93 octane Sunoco, which seems to be giving me the best mpg and smooth acceleration/idle. And every station around here adds 10% ethanol.
Old Apr 26, 2011 | 05:56 PM
I wasn't really paying attention to my MPG but i think it is better than ARCOS
Old Apr 26, 2011 | 08:29 PM
vqsmile's Avatar
Originally Posted by entgunguy
in california gas from costco and arco have a high ethanol content- i have noticed decreased acceleration and mileage. not sure about nevada gas though.
That's interesting. I just filled up at Costco last time and I've noticed that my mpg is definitely down compared to the last few fill ups I did at Chevron. Damn ethanol; what a crock this stuff turned out to be. (unless you're turbo'd)
Old May 2, 2011 | 08:41 PM
soltis007's Avatar
Will you actualy notice a difference with mpg immediately with a bad gas fill? I used Costco gas recently but I can't believe that one gas will be that much different than another.
I don't want to start a debate but can someone answer why one fuel additive is that much dramatically better than another?
Want to be educated pls.
Old May 2, 2011 | 10:06 PM
vqsmile's Avatar
^^ You're lucky you're not in California. We get get winterized gas that is just poo. I'm not sure when they switch over to summer blend, but the energy content of the winter blend is definitely less. I did notice a major difference between Chevron and Costco. If they are using lots of ethanol in the Costco gas, then that alone could explain it. Adding ethanol yields a higher octane rating, but the energy content is lower than if it were just plain gasoline.
Old May 2, 2011 | 11:36 PM
soltis007's Avatar
I don't think costco uses ethanol, don't they have to state it on the pumps? Been looking & haven't seen it on there.
Old May 3, 2011 | 01:11 AM
vqsmile's Avatar
Like I said, you're lucky you aren't in Cali.
ALL pumps here say that they may contain "up to 10% ethanol".
Old May 3, 2011 | 07:42 AM
soltis007's Avatar
OOOOhhh. Yuck. Didn't know that last time I was in Cali I wasn't doing the filling up my boss was....got it.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
