stripped nut on strut tower
Old Apr 2, 2011 | 06:29 PM
bat6wc's Avatar
Well, someone (cough cough, dealer) overtightened the nuts on the strut towers. I managed to get 5 of the 6 off but the 6th is stripped. Cant seem to get this nut off with any size socket or crescent wrench. How do I get this thing off? Cutting the only option? Obviously, im not worried about the nut itself, but the stud, id like to keep intact.
Thoughts? Thanks
Old Apr 2, 2011 | 07:00 PM
mishmosh's Avatar
The threads are stripped or the outside of the nut? If it's the outside, use a bolt-out kit like one made by Irwin. If the threads are stripped. Try wedging a flat head screwdriver under it while you are turning it out.
I'm guessing this is related to the Alutec strut bar? Been there done that. I could not get a good threads on the nut to seat on the strut studs so I went bought nuts without the flange on the bottom. The thickness of the alutec is the problem--doesn't leave much stud left to tighten down so it is easy to overtighten.
Old Apr 2, 2011 | 07:08 PM
bat6wc's Avatar
outside of the nut is stripped. Bolt out kit eh? Available at lowes? I have the Grab It kit but thats more for screws and bolts versus nuts. and yes, this is with the alutec strut bar. luckily, its just one.
Lucky_One's Avatar
ive used these before on a stripped bolt from the exhaust.
http://www.sears.com/shc/s/p_10153_1...=1301785667124
Old Apr 2, 2011 | 07:43 PM
EnviedG35's Avatar
Just get a pair of vice grips and get it on there good and tight. That ought to get it off.
Old Apr 2, 2011 | 08:02 PM
bat6wc's Avatar
Lowes, home depot and sears did not have anything other than a grabit set. Vice grips didn't work/fit
Old Apr 2, 2011 | 10:13 PM
soundmike's Avatar
Try a Gatorgrip. Even our local WalMart and CVS has 'em.
Old Apr 3, 2011 | 07:23 AM
mishmosh's Avatar
Wow, I didn't think those would be good in tough situations. Guess that'll be something I will add to my toolbox.
Old Apr 3, 2011 | 08:21 AM
soundmike's Avatar
They work just fine for strut tower nuts, they're only torqued down to about 24 ft/lbs. (or anything in that range, basically).
I'm surprised y'all are having issues with the Alutec bar, i didn't experience this issue at all. Good luck, guys.
Old Apr 3, 2011 | 12:47 PM
bluedevils95's Avatar
+1 for this! This happens to me a lot at work and vice grips can save the day.
Old Apr 3, 2011 | 03:06 PM
bat6wc's Avatar
just spent 2 hours trying with no luck. Tried a size 11mm, tried vice gribs, tried the craftsman bolt extractor kit...nothing is working.
Old Apr 3, 2011 | 03:12 PM
PorschePhD's Avatar
Try a chisel. Hammer a groove in it then reposition and hit it from the side. If that doesn't work take a cut off wheel and cut to the threads then run the chisel in it and it will split the nut. I just spent two weeks redoing my who suspension and must have done this no less than 10 times.
Old Apr 3, 2011 | 03:36 PM
bat6wc's Avatar
i cant even get in there with my dremel...its the back nut thats hard to get to.
Old Apr 3, 2011 | 05:08 PM
EnviedG35's Avatar
If at all possible, find somebody that has a welding machine. That way you can use a smaller socket and place it on top of the nut and place a tack weld between the socket and nut. That should be plenty strong enough to get the nut off.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Claudiu
Sep 26, 2015 01:04 PM
