Tools & DIY needed for spark plug change
Old Apr 14, 2011 | 03:54 PM
eddystone's Avatar
What are the tools needed to change our spark plugs? I couldn't find any DIY for our car and if someone could list one that would be great.
Should I just get the factory plugs or buy NGK? if NGK, which exact one should I buy?
Old Apr 14, 2011 | 04:35 PM
kool_yaar's Avatar
whats the mileage on your car? are you having any problems? i ask cause our cars come with DENSO iridium tipped plugs which are good for up to a 100k.
If you want to change then you should be able to get any good iridium plugs you want that are pre-gaped to 1.1mm or you can diy, the plug change should be as easy as any other v6, you will need the special park plug deep socket with rubber on top to get the plugs out easily.
There should be a DIY for the previous gen, google it and it should be very similar to it.
Old Apr 14, 2011 | 04:37 PM
kool_yaar's Avatar
What do you know, i googled it and actually found a DIY for the 2nd gen, Enjoy!
Spark Plug DIY 2nd Gen
Old Apr 14, 2011 | 06:57 PM
eddystone's Avatar
About to be 160,000 kms. It's time to change right?
Thanks, I only did a search on this forum but didn't think about Google.
Old Apr 14, 2011 | 08:38 PM
kool_yaar's Avatar
^ ya thats about the right time to do it, should be beneficial.
Old Apr 14, 2011 | 09:15 PM
lsmooth81's Avatar
i believe our cars come with NGK spark plug as OEM, at least my car did.
Old Apr 14, 2011 | 11:11 PM
kool_yaar's Avatar
^ thats what i thought cause on my buddy's 05 coupe they were NGK but the FSM for the 07+ say DENSO and my buddy's car had already had one tune-up before so its possible they put in NGK then, either way they are both high quality plugs.
Old Apr 15, 2011 | 12:14 AM
lsmooth81's Avatar
I think from 07+ might be different, I just looked up the part number for OEM plugs for 03-06 G35 and they are NGK. But Denso are not bad either.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
ghost_g35
Aug 7, 2015 10:31 AM
kinetek
Aug 3, 2015 04:25 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
