Squeeky belt..does anyone have a quick fix??
Old Apr 25, 2011 | 04:48 PM
Eug96's Avatar
Good Afternoon,
Lately when starting the car one of the belts(at least this is what I think it is) is squeeking every 2 seconds..as I increase the speed the squeek will increase as well. Thought one of the belts might be wet but after a dry spell I dont think thats the problem Anyone experiencing something similar?...
Just as the warrenty expires all hell is breaking loose.
Old Apr 25, 2011 | 05:10 PM
gtbigup01's Avatar
Maybe it's time to replace them. It's a 30K mile requirement by the book. Of course some will say you can go longer, and maybe you have! Squeak squeak. Could also be the tensioner/pulley/Alt bearing or waterpump bearing. Since the belt goes around all those tings it's hard to tell which one is causing the squeaking.
Old Apr 25, 2011 | 06:07 PM
RedBaronK's Avatar
Mine is at 35k and so far it still looks new... I figured i'd change mine when it starts getting frizzy around the edges
Old Apr 25, 2011 | 06:29 PM
treacherous's Avatar
20 Year Member
G35x
Mine looked fine but started to emit some chirps in the morning. I replaced belt and noise went away.
Old Apr 25, 2011 | 10:39 PM
kool_yaar's Avatar
^ like they said you might have to replace the belt, i keep telling myself to do it but keep forgetting and the belt is still visibly fine at over 53k miles. but its a cheap easy DIY which should be done around 45k or when it looks worn out/squeeky imo.
Old Apr 25, 2011 | 11:27 PM
Eug96's Avatar
thanks, will have it replaced..how much would the part roughly be?
Old Apr 26, 2011 | 11:11 AM
RemmyZero's Avatar
i put a DIY in the DIY section. i think the belt was $24 or $30 if i recall. should take you 20 minutes to do with the right tools.
if you absolutely have to wait then buy some belt dressing to spray onto the belt from autozone, pepboys, where ever.
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
yosip1115
16
Sep 28, 2015 04:14 PM
mattdg35
Sep 14, 2015 11:28 AM
Mhacker
Sep 12, 2015 07:35 PM
