Tire/wheel sizes - Help needed
So im planning a list of mods for my car including wheels, I have read and searched thru out a lot of threads around here trying to figure out the right setup for my wheels and tires but still couldn't reach a decision. I have a 2008 G35 Sedan and my plan is either to go with Concept One CS-5.0 or 19" Varrstoen TE reps. I want a setup that flush with the body or a bit aggressive at the rear wouldn't be a problem.
+ im planning on lowering the car on coilovers + BBK (most probably Akebonos)
Concept one offsets:
20x9x +25,+35
20x10.5x +25,+45
I got these offsets from Varrstoen:
Hub bore 73.1
19x9.5 +0 5x114.3 black
19x9.5 +12 5x114.3 black
19x9.5 +22 5x114.3 black
19x9.5 +30 5x114.3 black
19x10.5 +0 5x114.3 black
19x10.5 +12 5x114.3 black
19x10.5 +22 5x114.3 black
19x10.5 +30 5x114.3 black
19x9.5 +12 5x114.3 Full polished
19x10.5 +12 5x114.3 full polished
Lexus hub bore 60.1
19x8.5 +32 5x114.3 black
19x9.5 +35 5x114.3 black
My Questions:
1) should i consider different offsets between size 19 and 20
2) what would be a good setup for size 19 and 20
3) what tire size should i go with the wheel setup
4) any custom work should be done (spacers, negative camber, fender rolling, etc...)
5) what is G35 sedan Hub Bore size
and Thank you in advanced.
20x9x +25,+35
20x10.5x +25,+45
Hub bore 73.1
Lexus hub bore 60.1
My Questions:
I feel you man I'm trying to figure out the offset thing right now. this may help http://www.1010tires.com/wheeloffsetcalculator.asp
yes, mostly in size 20" havent seen 19's with 10.5 yet
+what is G35 sedan Hub Bore size?
Bump no help around here
I believe the hub is 66.1mm
theres a few on the east coast thats running 19x 10.5 +12 offset on 1st and 2nd gens 4door. And yes the hub bore size is 66.1
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
