2nd gear notchy?
Old May 13, 2011 | 04:21 PM
Wannabe6MT's Avatar
-MN G Crew-
2nd gear notchy?
I think somethings weird with my 2nd gear. Today I got on it a little bit, and went to quick shift into 2nd, and it grinded really bad. Clutch was in, wasn't my grinding. Its like it didn't want to engage into 2nd.
So i putsed around with it, and noticed that 2nd gear is harder than the other gears to get into. Its like its notchy almost. Is this a known problem or am I just high?
Old May 13, 2011 | 04:55 PM
kool_yaar's Avatar
it should not be grinding, however there is an occasional clunking sound when the tranny is cold, redline shifts to 2nd should be smooth and easy with no grinding, howevr at lower rpms it can clunk at times when cold.
Old May 13, 2011 | 05:01 PM
thescreensavers's Avatar
Mr.202?
didnt you get a new tranny? lol
Old May 13, 2011 | 05:44 PM
Wannabe6MT's Avatar
-MN G Crew-
^No, they couldn't get it to simulate the 6th grind I randomly experience.
The car was fully warm (it was after I had been driving around all morning) and the temp outside is probably 60. It just seems harder to get into and it grinded when I quick shifted...
Old May 13, 2011 | 06:33 PM
kool_yaar's Avatar
^ maybe a synchro problem, not sure how many miles or how the last guy drove it but i would look into changing the MT fluid first off and test if your clutch is ok (which it should be since all other gears work fine) then change out clutch fluid which is very easy if you dont want to get underneath the car then just use a syringe or baster to suck out old fluid from reservoir, put in new dot4, close cap, press cltuch in and out slowly 20-30times and repeat until fluid stays clear.
In a safe empty lot or road, go upto ~35mph and then put your car into 6th gear and floor the accelerator for just a few seconds and if the car feels heavy and slowly tries to speedup your clutch is ok, however if the rpm quickly jumps up and the speed does not then your clutch is going bad soon.
If clutch checks out and changing the MT and clutch fluid does not help then it might just be a serious synchro prob which requires tranny replacement by infiniti since they never work on fixing the tranny themselves.
hope this helps!
Old May 13, 2011 | 06:35 PM
Locksmith's Avatar
Hope you find a fix Janik that would suck to have some tranny problems.
Old May 13, 2011 | 07:04 PM
Wannabe6MT's Avatar
-MN G Crew-
hope this helps!
Clutch is fine. Car is very jumpy at low speeds if im in 6th gear. Car only has 33k lol.
Yea, I'll ask the dealer about it this week when I go in for a oil change. Luckily I have a 100k warranty that goes until 2014.
Old May 14, 2011 | 03:22 AM
KulG35's Avatar
My second gear can be a near to get onto sometimes... Going fast, no prob! And not all the time... I skip in stop and go traffic
Thebaws11
Jul 2, 2021 11:36 AM
beto4632
Sep 23, 2015 04:28 PM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
