What services to do at 160,000 KMs?
Old May 13, 2011 | 04:30 PM
eddystone's Avatar
I am at 160,000 KMs but bought the car at 120,000 KMs, what services are recommended? I had changed the spark plugs, rotors & pads, transmission fluid, and steering fluid. What else should I do? like engine flush, radiator flush, etc...?
Old May 13, 2011 | 04:58 PM
kool_yaar's Avatar
u have x so front and rear differentials fluid change, air filter, oil change and that should do it really unless you are having some specific problems.
Old May 13, 2011 | 05:14 PM
FreshG's Avatar
I mean you got the main things done and the guy above me; gave some good options too. So if your not having any problems..no need to change. Some of things that is recommend by Infiniti. Most of the things you already have done, so your good to go.
Engine oil & filter
Engine coolant change
Transmission fluid change
Differential Fluid change
In-cabin Microfilter
Engine air filter
Drive belts
Tire rotation
Brake fluid change
Power steering fluid change
Old May 13, 2011 | 05:25 PM
eddystone's Avatar
I had Infiniti change my transmission fluid which I think is only the front. I bought K&N filter and recharge (cleaning kit) them every few months.
Engine oil & filter - Done
Engine coolant change - Will have to do
Transmission fluid change - Done
Differential Fluid change - Will have to do
In-cabin Microfilter - Done
Engine air filter - Done
Drive belts - Still looks good so I don't think I should
Tire rotation - Done
Brake fluid change - Will have to do
Power steering fluid change - Done
Old May 13, 2011 | 06:28 PM
kool_yaar's Avatar
those three are very important and often overlooked: diff, brake fluid, coolant. With all this done and everything you have already done you should be good to go!
Old May 13, 2011 | 08:22 PM
eddystone's Avatar
How much estimate would be for coolant change, diff change, brake change? So I don't get over charged.
Old May 13, 2011 | 09:10 PM
kool_yaar's Avatar
im guessing by brake change you mean just brake fluid change...
Stealership will rip you off for sure, someone who's had it done might share price here(my GUESS ~$4-500), as for DIY is pretty cheap obviously just need fluids for radiator, diff and brake which should come out ~$60-80 for quality fluids and if you have a local mechanic do it then i would estimate around ~$80-150 or more for labor depending on your relationship, state, reputation etc...
i can get my diff and coolant done for $60 plus supplies for example cause iv known the mech for 11years so it relly depends...
Old May 14, 2011 | 01:39 PM
Q8y_drifter's Avatar
Diff fluid change is pretty easy. All you really need is a pump to fill the new fluid.
Old May 18, 2011 | 03:16 PM
eddystone's Avatar
How to tell if I really need coolant and brake fluid change? if I change it now, when should I change them again?
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
f22raptor
Mar 18, 2016 08:50 AM
Tmatheso
Dec 13, 2015 03:24 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
