AT shift knob has a button. Can I put an aftermarket shift knob on without a button?
Old May 25, 2011 | 02:12 AM
Sprockethead's Avatar
AT shift **** has a button. Can I put an aftermarket shift **** on without a button?
Do you guys know what I'm talking about? The automatic transmission **** has a button that press to move it to Reverse, Drive, Neutral.
I see the M45 replacement for sale. I was thinking about getting it cause mine is scratched (I bought used). But does the lack of a button mess you up? Is there some sort of complicated "button override" mod that has to be done? Cause if so I'll just buy a replacement G35 ****, I guess.
Thanks for any knowledge.
Later.
Old May 25, 2011 | 02:47 AM
kool_yaar's Avatar
A lot of ppl have M45 AT shift ***** on G
Old May 25, 2011 | 03:01 AM
sdonabo's Avatar
^what he said
Old May 25, 2011 | 03:07 AM
ChinkyChoy's Avatar
https://g35driver.com/forums/accesso...t-*****-t.html
Old May 25, 2011 | 03:12 AM
lsmooth81's Avatar
+1.
Old May 25, 2011 | 03:20 AM
E-Ticket Ride's Avatar
Doesnt the m **** have a button?
Old May 25, 2011 | 05:43 AM
GXXXV X's Avatar
It just doesn't lock so it can be accidentally shifted but not a big issue
Old May 25, 2011 | 09:04 AM
Accidentally shifted to reverse? Usually that's what the button is for, right? So you don't just jam it in? Or am I showing my ignorance here. That's just an assumption on my part as to why there is a button in the first place.
Old May 25, 2011 | 09:10 AM
ilovez33's Avatar
Check eBay for a Razo RA89 Quick Shift AT.......
I have it in my car and its perfect.
Old May 25, 2011 | 09:12 AM
GXXXV X's Avatar
That is what I've heard from others who have switched to a buttonless gear shift. Yeah the whole point of the button is to lock it so you don't hit reverse or park in certain instances
Old May 25, 2011 | 09:29 AM
I take it there are no options for an aftermarket **** that has a button on it?
Old May 25, 2011 | 04:56 PM
ilovez33's Avatar
The RA89 is buttonless but still locks. If you take your shift **** off you'll see a blue trigger mechanism that pushes down. When it reach's a certain point down the lock is not engaged anymore. Most of the AT shift ***** will come with a seat that the shift **** sits around that will keep it the right height so it still locks but will still shift also
Old May 25, 2011 | 04:58 PM
Meh. I think I'll just wind up sanding off the scratches of my current one and putting it back on.
I think the former owner wore a lot of rings or something.
Old May 25, 2011 | 04:59 PM
ilovez33's Avatar
Yeah it happens. The oil from your hands really deteriorates at the leather there after awhile also.
Old May 25, 2011 | 05:01 PM
Interesting. Well if that's the case I'll steer clear of the M45 ****. If I replace, I'll go for the machined aluminum type. Thanks.
