vdc, slip, brake lights on dash ?!? help
Old May 30, 2011 | 03:48 PM
platinumg35x's Avatar
This has happened to me a few times now. Sometimes when I am driving my vdc off and slip light randomly come up on the dashboard (No, I don't hit the "vdc off" button on the side). This has happened to me a few times now. The first time it happened, I just turned off the car and it went away. But the same thing keeps recurring every now and then. Also, sometimes when I hit the throttle, my brake light comes on and then goes away as soon I let go of the gas. Car is driving fine and the same as it was before all these lights started popping up on my dash. Anybody have this issue before or know what it is? Thanks.
Old May 30, 2011 | 04:09 PM
vdoh8687's Avatar
This happened to me a few times too, I have an 07 G35x, and it was because the brake fluid was low.
Old May 30, 2011 | 04:14 PM
just the brake light? or the slip and vdc lights as well?
Old May 30, 2011 | 04:23 PM
Supremee's Avatar
nooobs lol nah its a reminder that either brake pads, or brake fluid is low - change it asap
Old May 30, 2011 | 04:40 PM
kool_yaar's Avatar
over 50 threads on this, as they said youre low on brake fluid which is mots likely cause of running low on pads.
Old May 30, 2011 | 05:47 PM
sdonabo's Avatar
gotta work on tour breaks.mines doing it 2
Old May 30, 2011 | 06:01 PM
My Key's Avatar
brake fluids low due to brake pads wearing down. change asap
Old May 30, 2011 | 09:02 PM
Fendi35's Avatar
yea what they said
Old May 30, 2011 | 09:28 PM
salvador312's Avatar
DAMN!!!!! I got the same lights too, I just swapped to AKEBONOS but I hadn't look into it yet!
Old May 30, 2011 | 10:03 PM
RedBaronK's Avatar
Search function will yield results mentioning that this is from the brake pad(s) in ur car wearing out...
Old May 31, 2011 | 12:58 AM
vqsmile's Avatar
Guys, I think this is a bit of misinformation. Typically, the lights conservatively come on very early with MANY thousand miles left on the brakes. If you just add some fluid you should be good to go for quite a bit longer, just don't forget to suck that extra fluid out when the brake pads are finally changed.
Old May 31, 2011 | 10:07 AM
Ahahahh? I just added fluid and lights are gone!
Old May 31, 2011 | 10:36 AM
My Key's Avatar
well.. true.. its not too pertinent, but something to keep an eye out for.
Old May 31, 2011 | 09:07 PM
djfarhan's Avatar
https://g35driver.com/forums/v36-bra...ts-coming.html
Old Jan 23, 2017 | 02:37 PM
Gkgrijalva's Avatar
That was true to my problem... I have a 2005 Infiniti G35 Sedan with the VDC, Brake, and Slip lights on and by adding DOT 3 Brake Fluid I fixed the problem. Thank You For Your Help.
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
Wayne9011
Jul 27, 2015 11:25 AM
Lsantana757
Jul 20, 2015 09:08 AM
