Tires for Infiniti G35Xs
Old Jun 12, 2011 | 06:13 PM
skiddw's Avatar
Guys
Im looking at GoodYear Tpc 1257ms Eagle P225/50R18 Front and Back.
Should I stagger the size between the front and back ?
Front Tire Size: 225/50R18
Rear Tire Size: 245/45R18
Old Jun 12, 2011 | 07:45 PM
LakeShore_Slate's Avatar
If you want to pay more, want that aesthetic look, and don't mind rotating after every other oil change.
Old Jun 12, 2011 | 11:13 PM
vqsmile's Avatar
Hmmm... To be honest, I never much saw the point of rotating a staggered setup at all.
Old Jun 12, 2011 | 11:42 PM
RedBaronK's Avatar
Originally Posted by treacherous
Just an FYI from owner's manual page 8-35. This is for X models.
"Always use tires of the same type, size, brand, construction (bias, bias-belted or radial), and tread pattern on all four wheels. Failure to do so may result in a circumference difference between tires on the front and rear axles which will cause excessive tire wear and may damage the transmission, transfer case and differential gears."
^i am with him... different tires screws up an X. Only works well on rwd
Old Jun 13, 2011 | 06:04 PM
skiddw's Avatar
Is the GoodYear Tpc 1257ms Eagle P225/50R18 a good tire I can get them at a good price
Old Jun 14, 2011 | 12:04 AM
lefizzet's Avatar
This topic never seems to get old lol. You can run staggered tires FINE on an X. I have been running my staggered setup for well over a year with absolutely ZERO problems. Here's what you do
1. Go to a tire size calculator website
2. Plug in your tire sizes
3, Make sure they are similar in diameter/circumference
4. Enjoy
But in your case I don't see a point. What wheels are you running? Most people run staggered sizes for the look but the sizes you listed would barely be noticeable. In your case I wouldn't run 225/50 and 245/45 it's about a half inch (14mm) difference in circumference.
Old Jun 14, 2011 | 12:35 AM
vqsmile's Avatar
4. Enjoy
I believe the more pertinent debate is over what window of tolerance there should be in the definition of "similar" .
Old Jun 14, 2011 | 12:38 AM
lefizzet's Avatar
Yeah forgot to specify lol the "accepted" rule is 3% difference.
Old Jun 14, 2011 | 09:08 AM
oops, yea mean't to say *not* rotating.
Old Jun 14, 2011 | 10:24 PM
RedBaronK's Avatar
This thread is like the subject of turning the x into a rwd.... why not just buy a rwd to begin with and stagger wheels or go fully rwd???
Old Jun 14, 2011 | 11:51 PM
lefizzet's Avatar
Always the possibility it might give a dealer the justification to deny a warranty claim on the AWD system.
Yeah but I'm saying there won't be a problem if you're doing it right. (knock on wood ) If you want to be safe with the dealer, you could always swap to an oem set if you have two sets of wheels.
Not sure where you're from cause your location isn't specified, but do you know how rare an S even a journey model is in the northeast compared to an X? 99% of all models new or used on in dealerships happen to be an X unless you are placing an order directly with Infiniti. That makes finding a RWD G in your preferred specs almost impossible.
reavensf
Sep 17, 2015 11:30 PM
socalg35x
Aug 7, 2015 09:36 AM
Mac8008
Aug 4, 2015 09:19 PM
rping
Jul 26, 2015 09:53 PM
