BC coils poor quality????
Old Jun 18, 2011 | 06:42 PM
boostd7's Avatar
I just finally finished up installing the fronts and rear perch springs without a problem. I finally get to the rear adjustable struts and they are damaged. wtf
they were packaged pretty well with bubble tape. I m not sure if they were damaged at the factory.
I have to contact jwauto to see what to do. my car is in pieces and I need to get to work. I m not sure I will rust or if the gold ring will turn over the damaged portions.
I can't get a freaking break.
just unwrapped
close ups
Old Jun 18, 2011 | 06:44 PM
boostd7's Avatar
only concern is the deep chips in the rings. I m not sure if the ring will slide over it smoothly or get stuck. my teins don't like to turn if I get sand between the rings and strut body. i m really bummed. I wanted to see what it would like with a drop yesterday.
Old Jun 18, 2011 | 06:46 PM
boostd7's Avatar
on the right hand side of the sticker it says R. i also hope I don't have two rights. do they come left and right for the rears? thanks
Old Jun 18, 2011 | 06:58 PM
mao's Avatar
mao
I think the "R" stands for "rear", rather than left or right. i don't believe coilovers are made "side specfic".
Old Jun 18, 2011 | 07:00 PM
boostd7's Avatar
cool, good to know. u think the chipped portions would be ok.
Old Jun 18, 2011 | 07:08 PM
E-Ticket Ride's Avatar
Just screw the collar up and see if it gets stuck or not. If it does, return it. If not, you're GTG.
Old Jun 18, 2011 | 07:11 PM
bluedevils95's Avatar
I am checking this out because I was planning on getting those. I thought this was good coilover?
Old Jun 18, 2011 | 07:17 PM
mishmosh's Avatar
Are those pieces of metal burr in the threads or did the threads get dinged. Try cleaning up those threads before you turn the gold rings over them. Looks like it should be fine though.
Old Jun 18, 2011 | 07:27 PM
apexi957's Avatar
Mine were fine
Old Jun 18, 2011 | 07:54 PM
soundmike's Avatar
This.
Originally Posted by apexi957
Mine were fine
Ditto.
Definitely give this a shot.
Old Jun 18, 2011 | 08:23 PM
boostd7's Avatar
The threads got dinged. I don't want them to say I screwed it up when I installed. I guess I can put them on bc they were untouched when I took pics
Old Jun 18, 2011 | 08:25 PM
boostd7's Avatar
Will slap then on tomorrow
Old Jun 19, 2011 | 02:42 AM
ChinkyChoy's Avatar
didnt have any probs with mine
get some pix too after you install please lol
Old Jun 19, 2011 | 11:12 AM
SE-R / GTi-R's Avatar
If you contact BC they will ship you another set.
But by the looks of it you should be fine
Old Jun 19, 2011 | 11:44 AM
soundmike's Avatar
Just occurred to me, why does your set say 04+ G35AWD? Are you not a 2nd gen?
They're probably the same but just thought i'd point it out.
