Cabin Air Filter
Old Jun 28, 2011 | 02:39 PM
dohturdima's Avatar
I changed my filter 5K miles ago to Fram Fresh Breeze, but now have a loud airplane-like noise when I switch the HVAC to outside air (none when switched to cabin recirculate). Thinking that I installed the filter incorrectly, opened it up and changed the arrow position - nope, same issue. Noticed that one of the dash panel screws was missing - could it be causing the problem (don't see how)? Living with it for now by mostly turning up the stereo - still, it is annoying.
Old Jun 28, 2011 | 04:05 PM
Sprockethead's Avatar
So which way do you have the arrow pointing now?
Old Jun 29, 2011 | 06:04 PM
drivethefive's Avatar
doesn't seem like there is a consensus on which way the arrow points. Does it depend on the brand of filter you are using? Looking to do this soon since I turned on my a/c at full blast yesterday and it smelled like a wet dog for a few seconds. And I don't have a dog...
Old Jun 30, 2011 | 03:34 PM
g0tb00st's Avatar
is the DIY instruction video for the 1gen the same for the v36?
Old Jun 30, 2011 | 04:26 PM
rpm&my_G35's Avatar
Not sure what video you refer to but here...use the video for the 2nd gen
Old Jun 30, 2011 | 05:39 PM
g0tb00st's Avatar
There was a video on the first page of this thread. That's the video I was referring to. Thanks for this pointer.
BTW where can I buy a filter? The stealership is asking $50 for the oem filter kit.
Old Jun 30, 2011 | 07:32 PM
anderson1137's Avatar
Eff that! i bought mine for $14 bucks. works just as well as OEM.
Old Jun 30, 2011 | 07:34 PM
http://www.youtube.com/watch?v=3I5RL0VbYe8
Or you could find a DIY thread in the DIY section. I tried using the video but i couldnt figure out how to get the screws in the back. Moved on to the DIY thread, and it helped me alot.
Old Jul 1, 2011 | 12:16 PM
RickBlkG's Avatar
Do you really have to take all the trim off? seems like you can get away with just taking the glove box off. Seems like the same install I have done in my old car.
Old Jul 2, 2011 | 07:58 PM
RickBlkG's Avatar
Am I missing anything I took the four screws on the top out then the two on the side. PS I have an 08
Old Jul 2, 2011 | 08:00 PM
there should be one in the back. Right at the top behind the console. Its all the way in the back u might need a extension for ur screwdriver and maybe a light to find it.
Old Jul 2, 2011 | 08:28 PM
RickBlkG's Avatar
Thanks I see it now (used a flash light). Your right I will need a extension cant reach all the way back there. Just to double check is it the screw on the upper right side, all the way in the back.....
Old Jul 2, 2011 | 08:32 PM
I thought it was close the the middle, if you look at the video above for the g37 at 1:05 you should see the screw clearly.
Old Jul 3, 2011 | 12:49 PM
RickBlkG's Avatar
no I dont have one in the middle like the video, but their is a similar one in the upper right can anyone confirm if its the correct one?
Old Jul 6, 2011 | 02:38 PM
  #30
RickBlkG's Avatar
Last question on this, I removed all six screws and both side and bottom panels. The problem is I feel a lot of resistance on the glove box when I try to take it off. Is this normal and should I muscle it out. I'm scared I will brake something like a clip. Can someone advise!
