Wheel Bearing DIY
Old Oct 24, 2015 | 02:28 AM
  #46
DMG311's Avatar
G35x sedan
Thanks! I just did both of my front ones again and rebuilt my calipers.
I'm working on two more diys:
1. Opening hood when stuck closed
2. Repairing leaking transmission lines.
Hope to have them up in the next few weeks.
Old Apr 11, 2016 | 02:06 PM
  #47
vqsmile's Avatar
NOTE: UPDATED TORQUE SPEC FOR FRONT AXLE NUT !!!
Contrary to the rather ambiguous torque specs given in the beginning of this tutorial, the correct factory torque specification can be found the the FSM, Front Axle section, page FAX-16.
The correct spec is 92 ft.lbs.
ref:http://www.nicoclub.com/FSM/G35/Sedan/2008/FAX.pdf
EDIT: ADDITIONAL UPDATED INFO FOR TORQUE SPEC ON BRAKE CALIPER TORQUE MEMBER
To clarify the ambiguous value given for the front brake caliper torque member, the correct spec can be found in the FSM, Brake section, pages BR-38,40,42, and 45.
The correct torque spec is 98 ft.lbs.
ref: http://www.nicoclub.com/FSM/G35/Sedan/2008/BR.pdf
Old Apr 11, 2016 | 02:44 PM
  #48
Urbanengineer's Avatar
Thx ^ .
Old Jun 19, 2016 | 09:30 PM
  #49
rtb1010's Avatar
Thumbs up 2008 G35x Wheel Bearing Replacement
I had a bad front left bearing after about 80K miles. Found this thread and decided to replace it myself. While I haven't done a repair this extensive on my car yet, the DIY made it seem very straightforward. Ordered a Timken HA590125 from amazon and got to work. While the DIY is missing some pictures, I found everything to be fairly easy - the only issue I had was the order of the shoe removal vs caliper removal. I had to remove the caliper first, then take the shoe off. Other than that, it was fairly easy. Getting the hub off took a bit of time as it was rusted on pretty good, but slow persistence with the hammer and lots of pb blaster got it off.
Thanks to DMG311 for the clear instructions! I LOVE not having to shell out 5-600 per wheel for these types of repairs as I now feel very confident I could do brakes/calipers/rotors/bearings on any tire.
Old May 10, 2019 | 11:11 AM
  #50
dookie's Avatar
Just an FYI to anyone doing this... be wary of that ABS bolt! Last night I replaced the driver's front hub and the ABS bolt head snapped off with almost no force whatsoever. Job that should've taken 1hr or less took about 3 hrs.
Also, don't forget that on the G35S RWD the fronts don't have an axle nut
for the 07 G35S I used the timken hub Timken HA590376 ~$130.00. Note: the Arrow on the back of it points UP. doesn't mention that in the install instructions in the box...
Old May 13, 2019 | 07:45 AM
  #51
Joenavy85's Avatar
G35x Base
You can also look at the little stamped sheet metal piece that goes around the ABS ring, it has 2 cutout holes so that it can go in either knuckle and still accept the ABS sensor. I was fortunate enough to not have an issue with the sensor bolt, but I had my EZ-Out just in case.​​​​​​​
Old Oct 28, 2020 | 09:16 PM
  #52
909's Avatar
909
Your mom's boyfriend
Anyone archive the original DIY pictures ?
Old Apr 4, 2026 | 05:31 PM
  #53
supranatural's Avatar
Very helpful thread. I just did the passenger side, going to do the other side either tomorrow or next weekend. The way I got the hub out was some hammering with a hand sledge and then when I could see a small gap developing between the dust shield and the hub I took a chisel and hammered that in to open up the gap and get it out. My other thought for the driver side hub is to remove the back bolts to the hub halfway and hammer on them to get the hub to pop up from the back - I would use a round piece of steel stock I have in my garage for doing similar things.
Old Apr 4, 2026 | 10:56 PM
  #54
treacherous's Avatar
20 Year Member
G35x
I used this tool.. not cheap but popped off easy without much work
Amazon Amazon
https://g35driver.com/forums/g35-sed...ml#post7225762
Old Apr 4, 2026 | 11:20 PM
  #55
https://www.amazon.com/dp/B09VGDXKGY
That looks like a good tool, in the description they mention a newer version, it's a plate that also bolts onto the hub but uses a screw to push it against the knuckle to press the hub out, I was going to try to weld something up like that if I couldn't get it off with the sledgehammer. The updated tool is $44 so I may get that for the driver side hub to make it easier and especially if the old method of using a sledgehammer doesn't work as well on the other hub.
This is the "updated" tool.
Amazon Amazon
and another version for $33:
Amazon Amazon
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
Daniel k.
Nov 3, 2015 09:52 AM
wuppiedog
Aug 7, 2015 11:16 AM
