high idle
Old Jul 6, 2011 | 11:38 AM
zoop425's Avatar
high idle
I have not cleaned my tb's yet but wanted to chrck first. My car idles around 1k then moves up to 2k slowly after turning it on.. that seems insanly high..! Ideas?
Old Jul 6, 2011 | 11:58 AM
sharkcityG's Avatar
Mine did that too for like 3 days right when I turned on the car the rev was between 2000-2500 rpm so what I did was I put my right foot underneath the gas pedal n lightly pushed it toward me and after that it idles perfectly
Old Jul 6, 2011 | 12:01 PM
LordFappington's Avatar
You need to reset your TB, more than likely you messed with the valves and now its position is out of wack.
Old Jul 6, 2011 | 12:14 PM
RickBlkG's Avatar
Might need a tune up!
Old Jul 6, 2011 | 01:04 PM
InfinitJazz's Avatar
You haven't touched your tb's yet and it's already doing that? You may want to try the idle relearn procedure if it doesn't reset itself after a few startups. Though I never had any luck out of the twenty or so times I tried resetting mine. Luckily the dealer was able to reset it after a few attempts with the Consult computer.
Old Jul 6, 2011 | 02:48 PM
MHellmann's Avatar
Do your accelerator pedal released learning and then throttle body learning procedure. Then do the Idle air volume learning, the first two are simple key on and off procedures, the idle air volume takes a few tries, but you will get it.
Accelerator Pedal Released Position Learning ABS0037G
DESCRIPTION
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator
pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time
harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF wait at least 10 seconds.
Throttle Valve Closed Position Learning ABS0037H
DESCRIPTION
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by
monitoring the throttle position sensor output signal. It must be performed each time harness connector of
electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning ABS0037I
DESCRIPTION
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific
range. It must be performed under any of the following conditions:
Each time electric throttle control actuator or ECM is replaced.
Idle speed or ignition timing is out of specification.
PREPARATION
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
Battery voltage: More than 12.9V (At idle)
Engine coolant temperature: 70 - 100°C (158 - 212°F)
PNP switch: ON
Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, set lighting switch to the 1st position to light
only small lamps.
Steering wheel: Neutral (Straight-ahead position)
Vehicle speed: Stopped
Transmission: Warmed-up
For models with CONSULT-II, drive vehicle until “FLUID TEMP SE” in “DATA MONITOR” mode of “A/T”
system indicates less than 0.9V.
For models without CONSULT-II, drive vehicle for 10 minutes
BASIC SERVICE PROCEDURE
Revision; 2004 April 2003 G35 Coupe
1. Perform EC-46, "Accelerator Pedal Released Position Learning" .
2. Perform EC-46, "Throttle Valve Closed Position Learning" .
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
5. Turn ignition switch OFF and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops
blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the
specifications.
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried
out successfully. In this case, find the cause of the incident by referring to the DIAGNOSTIC PROCEDURE
below.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
