2nd Gen Random Little Question Thread!
Old 04-06-2013, 09:18 PM
pwntu's Avatar
I need to get my brake rotors changed, and i was wondering if anyone has any suggestions? I have an 07 g35x sedan. I want something that would give me a nice look like brembos but keep me on a budget. Really like drilled rotors with the red calipers.
  #122
Old 05-02-2013, 08:46 PM
413G35x's Avatar
Can anybody help?
Can anybody tell me if a 08 g35 sedan rear door fit a 07 g35 sedan ?
  #123
Old 05-02-2013, 09:34 PM
vqsmile's Avatar
I wouldn't see any reason why it wouldn't.
BUT, you could always just see if the part numbers for them are the same; you might even find them online with the help of google. . . . OR, you could contact one of our resident inhouse sponsors from various dealerships (Phil @Grubs, et al) and ask them to double check for you. . .OR you could call a local Infiniti dealership on the phone aand ask them to check for you...OR you could call a local bodyshop and have them run the part numbers through their estimating database and they should be able to tell if the body parts are the same.
.02
  #124
Old 05-05-2013, 10:50 PM
CorbinGandolfo's Avatar
new car owner please help!
Ok so I picked up my 07 g35x and was driving on the highway going about 130 km/h and the steering wheel would start to shake. I don't know if it was just the highway I was on because it would shake for a bit and then it would stop. Its not a fierce shaking but i am worried. Does anybody know what it might be? And also my service engine light is on. Do I HAVE to take it to a shop or can I DIY?
  #125
Old 05-05-2013, 11:19 PM
vqsmile's Avatar
Besides the pavement, there are any number of things that could cause the steering wheel to shake at 130kph ( approx 80 mph). It could be the alignment, a tire issue (imbalance or imperfections), bent wheel, steering problems, suspension problems, brake problems, etc. etc. etc.
After eliminating the particular road stretch in question, I'd start with a close inspection of the tires and then an alignment check as most likely causes, and then go from there if it still occurs.
As far as your SES light being on, for crying out loud...get that thing read already! (and report back with the code) You can typically either borrow a code reader (by a refundable deposit) from lots of major auto parts stores (ie. Autozone,ORielly, etc.), or you can get them done for free at numerous different service centers (ie. Mida muffler, Goodyear, etc.).
.02
  #126
Old 05-06-2013, 12:43 PM
StratoMX5's Avatar
Anyone with an 07 Sedan have rotor warping issues? Dealership replaced and they still warped within a few hundred miles. How'd you fix, just go aftermarket?
  #127
Old 05-06-2013, 01:07 PM
pwntu's Avatar
What exactly happens to you to believe that your rotors are warped? My car tends to shake a lot when braking from high speeds. I took it to a mechanic but i was told it was my control arm. I really dont know which one it is but im going to try to replace the rotors first and see if that helps. I would recommend the centric rotors with the stoptech pads if your looking for basic OEM replacement. Iv read a lot of good reviews on them.
  #128
Old 05-06-2013, 01:08 PM
GXXXV X's Avatar
I believe there was a tsb for that, for me they resurfaced the rotors and removed or changed the backplate thing... Look up v36 tsb, should be covered by infiniti
StratoMX5 (05-06-2013)
  #129
Old 05-06-2013, 01:09 PM
StratoMX5's Avatar
I'll check into it. Thanks G.
GXXXV X (05-06-2013)
  #130
Old 05-06-2013, 03:10 PM
vqsmile's Avatar
The TSB isn't really going to do much good for you. Most likely, your car is out of warranty coverage, so they're not going to do it for free like they sometimes did during the waranty period. Also, since the dealership already replaced the rotors and it came back shortly thereafter, they aren't going to replace the rotors with anything but the same factory parts, so theroretically, it should just come right back again on another set. I know the TSB has them add a rotor splash shield, but I think it is largely a bandaid of sorts, as many here have reported that it really didn't prevent it from occurring again.
A couple things you should know:
1) the most common issue with these brakes is NOT rotor warping, it is 'judder' which is caused by an uneven transfer of brake pad material onto the rotors. (btw, did the dealership replace the pads when they replaced your rotors?)
2) Judder can be prevented, or at least minimized, by learning to avoid hard braking followed by holding your foot on the brakes at a complete stop. SOunds crazy, I know, but once the pads are hot and you stop completely, they leave microscopic patches of pad material on the rotors on that exact spot. Do it enough times, and you get a buildup which becomes progessively worse and worse as the "bump" of built up pad material begets more uneven contact with the pads onto those same spots. Additionally, the rotor metal gets overheated at those spots which can actually alter the metalurgy of the rotor and lead to permanent damage.
All this info is available is countless threads throughout this forum, as well as a simple google search.
  #131
Old 05-16-2013, 02:44 PM
jdubin94's Avatar
I know we all love good quality parts but is it really a bad idea to buy ebay headlights? I just don't want to spend $500...
  #132
Old 05-17-2013, 10:02 AM
pwntu's Avatar
When accelerating quick in an 07 g35x, has anyone heard a blow-off valve type sound? I dont mind it, i just hope theres no problems with my car. Also, im about to hit the 80k mark, what are all the different fluids that need to be changed?
  #133
Old 05-17-2013, 10:06 AM
GXXXV X's Avatar
Hmm never heard a blow off noise with mine... It whistled kinda like a spooling turbo when in the parking garage though haha
  #134
Old 05-17-2013, 11:12 AM
b-dRizZy's Avatar
i heard that lol .. ^ when im punching it hard and its like at 6.5K RPM lol low key boost lol
  #135
Old 05-17-2013, 10:49 PM
vqsmile's Avatar
If it's a reputable seller, and they are factory lamps in good condition (all tabs 100%), then I'd don't see any problem at all.
Quick Reply: 2nd Gen Random Little Question Thread!
