lost my only key fob
Old Aug 22, 2011 | 11:58 PM
firozu's Avatar
Yes im an idiot and i lost my key for my car....
Does any one know how much it costs to replace and if i have to take the car to them?
Old Aug 23, 2011 | 12:15 AM
Sjshore75's Avatar
Search eBay. I have seen them for like $75. Only other charge is from the dealer to chip and cut it
Old Aug 23, 2011 | 12:17 AM
firozu's Avatar
do i have to take the car to them?
Old Aug 23, 2011 | 12:31 AM
Sjshore75's Avatar
I don't think so. Check out some other threads on here. I believe you just need to take it to anyplace that can cut and program the key.
Old Aug 23, 2011 | 12:56 AM
kool_yaar's Avatar
You can find it on ebay for about $30-40 for the remote and uncut key or this one with remote but PRECUT key(that wont work with your car) or even cheaper if you spend more time looking.
Also be aware that not all infiniti FOBs work on all Gs there is certain batch that can be programed to your car, for example 1st gen keys wont work or the newer FX ones form what iv heard.
You can get the key cut from anywhere as long as you have your valet key to help with the cut for the locksmith, for the remote programming you can just take the new FOB to the dealer with your registration card, VIN(already on reg card) and ID to prove the ownership and they can program the key for you without the car in a few minutes for about $20-50 depending on location and dealer
Old Aug 23, 2011 | 02:11 AM
bluedevils95's Avatar
If you lost it, i would get another key and I would also bring the car to them to reprogram the car to a new code. If that fob is lost then some clown could just push that button and off w/ your car. (just saying) To reprogram the remote is like maybe 100 buck from the stealersh*t
Old Aug 23, 2011 | 04:23 AM
dukehotty's Avatar
If you have the Intelligent Key fob you will have to get it programmed by the dealership. You should buy your own on Ebay and try and get it reprogrammed under warranty so that you don't have to pay for it. I called two dealerships and they had different prices to program between 100 and 120.
Old Aug 23, 2011 | 05:17 AM
kool_yaar's Avatar
^ wow those are crazy prices, my friend got it done for $40 at the dealership with a $10 off promotional coupon.
Old Aug 23, 2011 | 10:46 AM
Fendi35's Avatar
I know when I had my maxima I had an extra key but it wasn't programmed they charged me 110 to program it
Old Aug 24, 2011 | 02:25 AM
terrycs's Avatar
The car is technically programmed to the ikey(s).
The car has to be taken to either a Nissan or Infiniti dealer and ALL keys to be paired to the car have to be there at the same time the car is updated.
If you get one on ebay, check to make sure that it wasn't from the ikey recall.
Dallsinghjr1
Sep 17, 2023 11:25 AM
G35xdriver04
Nov 7, 2015 08:31 PM
douglas555
Sep 10, 2015 04:48 PM
