what average whp 2007g35x
Old Sep 1, 2011 | 06:54 PM
2evil's Avatar
my whp is 278 my bhp is 336 to 340 is this good whats the stock whp on a 2007 g35x mods are takada short ram intake, berk test pipes ,stillen cat back uprev dynod on mustang dyno @ r/t tuning
Old Sep 1, 2011 | 06:57 PM
lefizzet's Avatar
That's pretty solid for an X on a mustang dyno.
Old Sep 1, 2011 | 07:04 PM
rpm&my_G35's Avatar
Where are you getting the extra 30-40 bhp?
Old Sep 1, 2011 | 11:55 PM
GXXXV X's Avatar
what is bhp, is that measured at the crank or what? srs question
Old Sep 2, 2011 | 12:19 AM
kendroz's Avatar
245 to 255 stock whp. Depends on temp
Old Sep 2, 2011 | 12:20 AM
rpm&my_G35's Avatar
you got it.
Wiki
Brake horsepower
Brake horsepower (bhp) is the measure of an engine's horsepower before the loss in power caused by the gearbox, alternator, differential, water pump, and other auxiliary components such as power steering pump, muffled exhaust system, etc. Brake refers to a device which was used to load an engine and hold it at a desired RPM. During testing, the output torque and rotational speed were measured to determine the brake horsepower. Horsepower was originally measured and calculated by use of the indicator (a James Watt invention of the late 18th century), and later by means of a De Prony brake connected to the engine's output shaft. More recently, an engine dynamometer is used instead of a De Prony brake. Although the output delivered to the driving wheels is less than that obtainable at the engine's crankshaft, a dynamometer gives an indication of an engine's 'real world' horsepower after losses in the drive train and gearbox. This gives an accurate indication of how a car engine will perform when used normally rather than ideal non-loaded circumstances.
http://en.wikipedia.org/wiki/Horsepo...ake_horsepower
Old Sep 2, 2011 | 12:44 AM
GXXXV X's Avatar
thanks, i didnt know so many parts caused loss in hp!
Old Sep 2, 2011 | 11:18 AM
bluedevils95's Avatar
That is some good info. And that guy is getting some good number on his X
Old Sep 2, 2011 | 02:25 PM
broke_as_ajoke's Avatar
is the bhp.. same as the power coming out of the crank shaft?
g.spot
May 9, 2016 10:54 PM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
philthethrilloh
Sep 9, 2015 01:25 AM
