rear tire size (18's) QUESTION
Old Sep 27, 2011 | 05:35 PM
G3065's Avatar
Getting new tires for the rear and am wondering if 255's or even 265's would fit... searched the threads but couldn't find a page to pinpoint this question I had.
Old Sep 28, 2011 | 12:21 AM
vqsmile's Avatar
Yes, 255/45 will fit just fine on the rear. A 265 isn't as good of a fit as you'll need to drop the profile down at least to a 40 and even at that, it's a bit too wide for the rim. You'll lose a bit of performance on such a narrow rim as well as some smoothness from the drop in profile. Another consideration is: What you will be doing with the front tires size wise so that they match the diameters of the new rear sizes? If you leave the stock size (225/50) you may experience ultra sensitive VDC and/or SLIP complaints from your car's traction control system. A good partner for the 255/45 rears would be 235/50 fronts. They are only 1.5% taller than the stock size, but as a pair, they are nearly identical in ratio between front/rear as the stock set. This is a very good thing if you hate traction control overreacting whenever you take a freeway on ramp or make a tight turn. Here a tire calculator link for researching this a bit:
http://www.miata.net/garage/tirecalc.html
BTW, there are endless threads discussing all this; you need to sharpen those searching skills
Old Sep 28, 2011 | 12:47 AM
G3065's Avatar
Lol I will for sure! Thanks for your response it is greatly appreciated... Looks like I will have to wait it out and go with the 245's because the front 225's have a lot of tread left.
Once again thanks mate!!
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
nascarbuff17
Jul 16, 2015 10:23 AM
