Steering Wheel Trim Removal/Replacement DIY
Old Jun 30, 2019 | 03:16 PM
  #76
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Ok that part number does not fit the BASE model 2010 EX35, however it does fit the JOURNEY package EX35 so that should help a little (it's part of the TECH package which included the bluetooth hands free system). Not ALL websites show that intercompatibility though, not sure what's the deal with that.
However I'm not having any luck finding a decent price on that, $135 is about the best I can find for that part number.
I've used infinitipartsonline.com quite a few times now, it's a website marketplace for an actual Infiniti dealership in Arizona.
https://www.infinitipartsonline.com/...ver-48463jk07c
Just out of curiousity what's the problem with your existing one? If it's just scratched up then it can be refinished or vinyl wrapped and would be significantly cheaper than buying a new one. If it's completely MISSING then you could purchase a used steering wheel through eBay and if it's scratched up then just go the refinish route.
There's a few steering wheels for under $75 on eBay but that trim is either the wrong color or pretty thrashed. They would look fine wrapped or repainted though. You might drive around to some reputable body shops and/or stereo shops and see what they can do to install/refinish your existing one. Those guys regularly disassemble the steering wheel (especially stereo shops) and will have significantly lower hourly rates than the dealership.
Old Jul 1, 2019 | 04:10 PM
  #77
cmr372's Avatar
EX35
Thanks for the info. I’d read a thread about vinyl wrapping it but doubted I’d find a tan color to match. Mine is scratched up and it’s driving me crazy...that’s the only reason I want it fixed.
Old Jul 8, 2019 | 12:21 PM
  #78
Hoagy's Avatar
AWD Sedan
Originally Posted by Saaif88
Hopefully this will help anyone having this problem in the future:
I had this exact same problem where one of my screws came out just fine but the other one stripped completely. It's pretty much impossible to drill it out or cut a slot into it without destroying the plastic shroud. Instead of doing that, the thing that worked for me was a Bolt/Nut Remover Tool, specifically one that is sized for 3/8".
In Canada you can pick these up at Canadian tire, and all you have to do is hook it up to a ratchet or an impact gun and it will allow you to bite down on the bolt and remove it. Once they are out grab some M6 Hex Bolts of the right size and replace both of them to save you some headache in the future.
Best of Luck!
http://www.canadiantire.ca/en/pdp/ma...9532p.html#spc
Thanks this is exactly what I needed! I stripped both mine, even when I used the right security torx bit (cheap metal I guess), and was going to just try and jam the next size bit up in there and crank on it.
Old Jul 10, 2019 | 09:49 AM
  #79
towerdog81's Avatar
2008 Infinity G35X
Hey guys, I was able to do this Plasti dip fix right in the car without tearing down anything. it restored it better than factory. the plasi dip will not cut away like the factory crap. total fix cost 5-6 bucks plus some tape off material. just make sure you do at least 5 coats for quality and removal of overspray.
Old Jul 14, 2019 | 01:28 AM
  #80
cmr372's Avatar
EX35
Can you share a picture of the before and the product you used? It turned out great. Thanks.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
Karnicle
Jul 23, 2015 05:08 AM
