Interior door lock/unlock button doesn't work
Old Oct 1, 2011 | 11:22 PM
Ghost35x's Avatar
This is the second time this has acted up on me. My interior door lock/unlock switch wont respond. The fob works perfectly fine(locks/unlocks doors). It happened once a few months back, thought it was a glitch because it came back to life a few days later. Now the problem is back. This is on both interior door switches. Any ideas?
Old Oct 2, 2011 | 12:51 AM
redpearl99's Avatar
open up the door panel and check if the hardness to the interior switches is loose. also check to see if any of the wires to the harness itself are loose
Old Oct 2, 2011 | 01:51 AM
bluedevils95's Avatar
+1 for that. Let us know if that worked
Old Oct 3, 2011 | 06:44 PM
Ghost35x's Avatar
Doh! I should have been a little more thorough in my first attempt to figure it out. The passenger side door lock button was stuck in the lock position. I could press it to try and lock it and it would move, but it wouldn't fully return to neutral causing the drivers side to not work at all. I assume a friend spilled something (pop, gatorade ect) making it sticky. All good now.
Old Oct 3, 2011 | 08:53 PM
If your still under warranty you can have the dealers fix it for you
Old Oct 4, 2011 | 09:17 AM
kool_yaar's Avatar
^ he said he already fixed it, apparently some sticky soda causing it to not unlock.
tal1412
Nov 28, 2022 09:25 AM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
apintojr
Jul 23, 2015 10:52 AM
