RPM Shoots Up At Highway Speeds When Slightly Braking
Old Oct 2, 2011 | 01:13 PM
PJStyles's Avatar
I will be travelling at say 120km/h or ~ 80MPH and if I hit the brakes every so slightly because a car in front of me is say slowing down to 110km/h, my tranny shifts down and the RPM's shoot up from approximately 2,700RPM to 3,400RPM. It's very noticeable. I have an automatic transmission.
Interestingly enough, I had the computer reset and the ECU reprogrammed a few weeks back which corrected the issue, but it's back again. Anyone have any suggestions? It's causing for a very wacky ride as it relates to the RPMs.
No mods on the car - everything is completely stock. Any ideas/suggestions?
Old Oct 2, 2011 | 01:46 PM
kool_yaar's Avatar
Maybe youre experiencing the downshift rev-matching, which is normal when slowing down.... but cant say for sure with your description
Old Oct 2, 2011 | 02:30 PM
E-Ticket Ride's Avatar
Are you in D or DS? Sounds like engine braking
Old Oct 2, 2011 | 02:33 PM
apexi957's Avatar
Rev matching..
Old Oct 2, 2011 | 02:40 PM
vqsmile's Avatar
Yeah, it's actually a feature of the car. Driving in DS will make it more sensitive than in D.
Old Oct 2, 2011 | 02:49 PM
Massios's Avatar
Its just your torque converter lock-up.
When shifting into DS mode it engages the 4th gear lock up. That is causing your rpm jump.
Pretty cute isn't it? All six of my gears lock up too. It's called disengaging the clutch.
Old Oct 2, 2011 | 07:03 PM
PJStyles's Avatar
I do not have the car in any DS mode when this occurs. I'm using the regular DRIVE position. If this is a feature where the engine is used to brake or slow down, then I find it's engaging far too quickly. I'm talking the slightest braking at high speeds leads to high RPM. Weird.
Old Oct 2, 2011 | 07:11 PM
vqsmile's Avatar
Maybe it's worth checking with your dealer. It sounds like it is a bit over reactive if it's doing it in D. The increase in rpms is just because the transmission is downshifting, but a tap on the brakes at freeway speeds shouldn't force a downshift. Maybe the ECU reprogram didn't take and it's just relearning old bad habits.
Old Oct 4, 2011 | 01:42 AM
G3Sx's Avatar
What you are describing seems to be normal when driving in D mode. I double checked when I first noticed this. When running along backroads, I tap the brake just to the point of feeling the calipers grab. If done quick enough, the car will downshift one gear and be ready in advance for me to power through the turn. It will then shift up as I ease up on the throttle. This is different from torque converter lockup. If you want to know what it feels like to have the torque conveter unlock, place the shifter in DS and use it to shift up as you accelerate. Then try to lug the engine and you will feel the rpms go up a bit as you slow down (going uphill in 3rd or 4th without downshifting for example). All this will happen before the tranny downshifts as the tranny is smart enough to prevent actual engine lugging.
As far as having the tranny shift differently after resetting the ECU, keep in mind that the computer actually learns the way you drive and changes the shifting characteristics accordingly. This takes time and may not be immediately evident after an ECU reset.
Old Oct 4, 2011 | 10:54 AM
[DeVo]'s Avatar
I thought I had read somewhere that the car learns your driving style. Maybe if you brake on the highway, it's usually followed by some gas? I'm not sure if the learning algorithm is that sophisticated, but it might be.
Blakearold
Aug 19, 2015 10:20 AM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
joel extreme
Jul 27, 2015 11:59 PM
rping
Jul 26, 2015 09:53 PM
joel extreme
Jul 23, 2015 04:13 AM
