Rubber boarder around the sunroof cracked?
On a 2008 G35 with sun roof, the rubber that on the edge of the sunroof has many small cracks. You can see them outside of the car with the sunroof closed.
Is this going to be a problem?
$165? what the... Mine has the same issue and the color has faded too... I'm going to try some sort of product that is oily to prevent anything worse... I don't know if that this issue cause very small amount of water to drip in when going through a carwash.
If you are within your warranty period just bring it to the dealer and have them examine it. I did it with my car as a matter of fact. It had many small cracks around the rubber sunroof seal, and the dealer replaced the entire sunroof. They said it would have taken longer to just replace the seal!
Stuff like this makes me shake my head at Infiniti. It's like they are still learning to be a luxury car brand. Rubber seals deteriorating or seals around the doors falling off or steering wheel finish peeling should be happening!
well, at least it doesn't leak ...
I guess i will have that fixed before my warranty run out next year
its like, i hope it won't start leaking when after they fix the cracked rubber piece
my 4 yr 60k runs out next September, I have several issues like the sunroof cracking, think I'm going to split up the trips to the dealership so I don't go in there with ten things to do all at once. I would imagine they would be more inclined to do something if I don't give them a whole long list at once?
^ While there is some truth to that there are forum members who have had mixed results on the same warranty items. The dealership you take it to unfortunately does make a difference as some are hesitant to fix all warranty items and some will only do it if you complain enough. Still others have different ways of handling the warranty issue such as the roof above. Some dealers are replacing the entire thing! The probem is I don't take my car to the dealer to get service done (they are more expensive) and I feel if I'm only getting warranty work done they'll scoff at me a little
Is this what you guys talking about! Just went out and saw these tiny cracks!
