What is "Alert 0.5H" meaning
Old Nov 15, 2011 | 11:02 AM
vietkool's Avatar
My 35G, 2008, 39K miles. suddenly I got the alert msg " Aleert 0.5H" appeared on the dasboard screen. It went away when I turn off the engine and restart again. This msg appeared few time but I dont know what is mean? Can any one help me out?
Old Nov 15, 2011 | 11:39 AM
willdogs's Avatar
Google says
http://wiki.answers.com/Q/What_does_...an_Altima_2008
There is a very un-used setting in your alert window you can setup and use when you are on the road for extended periods of time. It's call the rest feature. You can program in the amount of time you would like to drive before your car will remind you that it's time to take a break.
To set/unset it go to your settings window, go to alerts and rest. Change it back to nill or "-" to unset it. That will stop it from popping up every half an hour (0.5h).
Read more: http://wiki.answers.com/Q/What_does_...#ixzz1dnDgwa7C
Even though this is for an Altima, I am pretty sure its the same thing for our cars.
Old Nov 15, 2011 | 11:44 AM
vqsmile's Avatar
Apparently, you need to take a nap
Old Nov 15, 2011 | 11:52 AM
vietkool's Avatar
oh, that is a reminder for some1 drive a long distance. it's nice feature but I dont think I need it cuz i am not gonna take a break 1/2h then continue to drive again ( took about 25mis to work place).
thanks guys.
One more thing happens it's really annoy me. when I step on a gas pedal, aggressive speed up, then the window appear a BRAKE light. It turn off right away but I dont know why it happen like that. is there some kind of limitation program to warn driver do not speed up so aggressively?
Old Nov 15, 2011 | 12:49 PM
RocG's Avatar
Check your brake fluid level. If it's below the max then top it off. I had the same problem and that fixed it for me.
Old Nov 15, 2011 | 08:48 PM
RocG's Avatar
Originally Posted by treacherous
If your brake fluid is low enough to trigger that light then you likely need to have your brake pads changed.
That's true, I'm near due on rear pads.
Old Nov 15, 2011 | 08:59 PM
vietkool's Avatar
My brake fluid level at between Min level and Max level. Is this may cause the problem for the brake light trigger when accelerate fast speed ?
Old Nov 15, 2011 | 11:39 PM
LakeShore_Slate's Avatar
LOL YES top it off
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Crisci33
Jun 29, 2017 08:31 AM
wuzz-upp
Oct 3, 2015 04:21 PM
