What do you do for maintenance?
Old Dec 28, 2011 | 01:21 PM
luger303's Avatar
Or what have you done that you think results in your car running better and longer than most.
I am trying to piece out my 60k service and I think i'm done, now at 66k.
So far I have:
Rotated the tires
Replaced Engine oil and filter
Cleaned my K&N air filter
Replaced the Cabin filter
Had my infiniti dealer change transfer case (AWD I believe)
Had my local shop (fantastic) flush Tranny Fluid AND Coolant.
Filled washer fluid
Filled brake fluid and power steering fluid to correct levels. (Do I need to flush these?)
What else........... Battery seems good, lube locks and hinges maybe.
Do I need to worry about the Diffs?
Is there anything that I am forgetting or should be forgetting? Thanks in advance.
Old Dec 28, 2011 | 01:43 PM
E-Ticket Ride's Avatar
IIRC, the belt is recommended at 60k
Old Dec 28, 2011 | 08:39 PM
jsolo's Avatar
Yes on the brake fluid flushing, yes on changing the rear end oil. Probably wouldn't be a bad idea to check the spark plugs too. I think they're rated for 100K, but getting them by that time might be a challenge.
On the topic of brakes, wouldn't be a bad idea to pull the pads, clean the debris/rust off the sliders, lube them (the sliders), and also lube the pad ears to prevent uneven wear.
For the power steering, fluid is cheap. Use something to suck out old fluid, add new, run the car for a bit while turning the wheels lock to lock ( to bleed the system), then repeat several times.
While you're under the car, make sure all the front end parts are tight and no play in the wheel bearings.
Old Dec 28, 2011 | 08:49 PM
luger303's Avatar
Great info. I will have to go to my friends house to use his bleeder. That gives me more to look into, thanks.
Old Dec 28, 2011 | 08:50 PM
jsolo's Avatar
I got the 'motive' bleeder. Relatively cheap, and works well.
http://www.motiveproducts.com/ . Dealer wanted $130 to bleed brakes on a diff car, so we bought this instead.
jsolo's Avatar
{duplicate, please delete}
Old Dec 29, 2011 | 01:40 PM
vqsmile's Avatar
In addition to changing your brake, P/S, and diff fluids (as others have mentioned), I'd change your coolant too. (Recommend using Nissan's newer extra long life kind)
Old Dec 29, 2011 | 02:47 PM
luger303's Avatar
Already did the coolant. But I didn't supply the fluid, so I have no clue whats in there. Yeah the brake and p/s are up this weekend (if I don't stay out too late). Diffs I will have to look into since I probably won't be doing those myself.
Old Dec 29, 2011 | 07:03 PM
vqsmile's Avatar
ahh, I see it listed there now; missed it the first time.
You really ought to consider doing the diffs on your own. It is a very simple job. If you can change your motor oil, you can change your diff oil too.
Old Dec 29, 2011 | 07:48 PM
luger303's Avatar
I'm trying to find a DIY on the VQ. I will give it a shot definitely. Thanks!
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
DRG35R
Sep 16, 2015 05:33 AM
