Painting stock calipers.
Old Jan 2, 2012 | 10:08 PM
blnewt's Avatar
Originally Posted by luger303
Wheels are in the future, I don't have 2k to spend right now. I just want to keep myself busy with the car. I am going to paint them black most likely. That shouldn't attract any extra attention to them but when you look close at the wheels it will look clean. ***, its forums like this that nudge me towards a Akebonos or Stoptechs etc......Thanks for all your input guys.
fyp
Old Jan 3, 2012 | 11:46 PM
drivethefive's Avatar
Originally Posted by blnewt
I used this paint and probably have the same stickers you found (the mt. fuji emblem)
Just a light rub down w/ steel wool, a spray w/ degreaser & a good rinse. Then you just shoot the calipers after taping off what you don't want painted and drive it hard w/ a lot of braking to bake in the paint. I ventilated the spray away from the car so no overspray issues. Haven't taken any pics of just the calipers but here's a couple pics of the front brakes for reference.
http://www.vhtpaint.com/products/caliperpaint/
Have any close ups? Would love to see them a bit closer even if the wheels are on. Think I may go this route, nice looking and subtle.
Old Jan 4, 2012 | 12:44 AM
botlfed98's Avatar
where do you get those stickers?
Old Jan 4, 2012 | 02:10 AM
IEMaestro's Avatar
Paint them black with white stickers and a couple layers of clear and you will be set.
Old Jan 4, 2012 | 08:04 AM
blnewt's Avatar
I'll shoot a couple at lunch and put em up
Old Jan 4, 2012 | 05:44 PM
blnewt's Avatar
Here you go, didn't have time to do any cleaning so they're a bit dirty
Old Jan 4, 2012 | 05:53 PM
luger303's Avatar
^^ Gangster!!
Old Feb 2, 2012 | 12:40 PM
luger303's Avatar
where did u get those center caps?
Old Feb 2, 2012 | 12:44 PM
bluedevils95's Avatar
When you going to paint them?
Old Feb 2, 2012 | 12:56 PM
luger303's Avatar
^ I didn't really wanna bring it up but I striped one of the lug nuts on the first wheel. Didn't even get the first wheel off, I had everything laid out and ready to work . I twisted some of the metal on one of the lugs and now can't even fit the 21mm over it. I will probably go to discount tire and have them pull it off for me. Then get some new black ones. I was using a 12 point socket, that was probably my problem, as well as not paying attention!!
Old Feb 2, 2012 | 02:27 PM
blnewt's Avatar
Here you go, and the cool thing is you can select the exact diameter you need, just don't press them on too hard when you apply them as it'll leave bubbles underneath. Luckily the shop sent another set
http://3dcarstickers.com/category/infiniti/
Old Feb 2, 2012 | 05:51 PM
luger303's Avatar
I just measured my center caps and they are 33mm.
Old Feb 2, 2012 | 08:28 PM
blnewt's Avatar
You could email the guy and ask if 33mm is possible, maybe you'd be in luck.
Old May 16, 2012 | 09:22 PM
luger303's Avatar
finally got em done. Im leaving for las vegas on Saturday and I had to rotate the tires so I figured this would was the best time. Worst picture possible, sorry. I am very pleased with the results though. G2 paint is easy to use and looks great.
zoop425
Mar 29, 2016 05:51 PM
Daniel k.
Nov 3, 2015 09:52 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
