Can't program Homelink
Old Mar 11, 2012 | 09:01 PM
Greenlawnracing's Avatar
Just got two new garage door openers and can't program them with my Homelink. Worked fine before.
Followed the instructions....cleared codes....put garage door opener into learn mode...firmly hit the Homelink button...no dice.
Even tried the "step by step" directions as if I was going to try it with the transmitter first. One thing to note is that the Homelink never gave me the indication that it detected a rolling code.
Ideas?
Old Mar 12, 2012 | 09:32 AM
matts08x's Avatar
That's pretty strange. It took me a couple times to get it right, but when I followed the directions in the manual, it seemed to work after the 2nd or 3rd try (which I believe the manual even said that it may take a few times to get it right).
Sorry, I don't have any ideas, just wanted to say that it took me a couple times to get it right. Maybe that's the issue with you, but I doubt it because of your comment about it not picking up the rolling code.
Good luck.
Old Mar 12, 2012 | 09:36 AM
Reading up on it a little bit, it sounds like the newer garage door openers aren't compatible with Homelink out of the box. Appears that you've got to buy some type of adapter. Excellent.
Old Mar 12, 2012 | 09:57 AM
Swagger_Jacker's Avatar
This is true. I just had an new Chaimberlain door opener installed and I tried to connect it too my G with no luck. Upon further research cars older then 2011 will not work with new openers, unless you buy a repeater. Has something to do with the new code rolling system they have. I think it BS personally cuz they want $50 for the repeater and it wasn't mentioned on the box or even when I purchased it. So for now I just have the opener in the car.
Old Mar 12, 2012 | 11:13 AM
rvanderwerf's Avatar
one thing I don't like about our homelink is you can break into the car and the homelink opener will work, that seems nuts to me, I think it should only work if the ignition is on and key is present!
Old Mar 12, 2012 | 12:06 PM
matts08x's Avatar
Yeah I thought the exact same thing numerous times. So basically, if your car is parked outside (which luckily, mine is not), someone just smashes the window and gains entry to your house. Great idea, vehicle manufacturers.........................
Old Mar 12, 2012 | 03:14 PM
rpm&my_G35's Avatar
^ or, if it really concerns you, flip the lock switch to your garage door at night (the one on the garage wall) so no exterior opener will operate it. Mine has one so I am just assuming most of them do.
Old Mar 12, 2012 | 10:04 PM
Or park in the garage you just opened.
I read a review on the Craftsman website that someone got a Homelink receiver just for the price of shipping. Hope I'm that lucky when I call tomorrow.
Old Mar 12, 2012 | 11:38 PM
Let us know how that goes and what you did, I may need to do that too.
Old Mar 18, 2012 | 09:15 PM
Called Homelink and they sent me a repeater for $7 in shipping. Your results may vary.
Old Mar 18, 2012 | 10:05 PM
What did u say to them?
Old Mar 19, 2012 | 08:09 AM
"Thanks for building a product that doesn't work with today's technology. Now send me a GD free unit before I go Honey Badger on your ***."
I just explained that it didn't work with my new GDO and they offered to send me this unit. Its a little jankety looking and has to be plugged in....sucks cause there are only so many outlets in the garage.
Old Mar 19, 2012 | 01:20 PM
Sweet ill give it a go. Do you happen to have the number to contact them? i tried going to the website but when i enter my car i get an error message.
Old Mar 19, 2012 | 07:35 PM
It appears that their website is down. Its in your manual, but if you can't find it let me know and I'll try to dig it up.
Old Mar 27, 2012 | 11:46 AM
So i called homelink and they told me i dont qualify for a free repeater. They had told me that its for 09 3rd quarter infiniti's. i mentioned that u had gotten yours but she told me that she wasn't sure how u got yours. I decided not to pay the $50. Not sure how you got lucky, but good job. I even tried using my truck which is an 04 Avalanche and still no good. Looks like i will stick with using just the remote.
