Putting stock springs back on
Old Mar 27, 2012 | 04:56 PM
Fendi35's Avatar
I love my car how low it is now, had it sitting on eibach springs. But the aligminet always was an issue. The shop i took it to did the toe on the front left the camber as it was and it was not eating up my front tires was really happy with that.
But the rear was a different story the camber was out and so was the toe. They had adjusted the best they can but went through tires in about 6 months. So i ended up buying camber arms and toe bolts, took it 2 different shops still coudent get the aligment striaght. When they do the camber toe goes out so they ended up doing the toe and camber is out a bit. Tired of throwing money on tires so i decided im just going to put back in the stock springs.
Old Mar 27, 2012 | 05:04 PM
rbayne's Avatar
Wanna sell me your Eibach's?
Old Mar 27, 2012 | 05:08 PM
Fendi35's Avatar
sure make me an offer
Old Mar 27, 2012 | 05:12 PM
Shanes_G's Avatar
thats too bad..should find a place that knows what they are doing.
Old Mar 27, 2012 | 05:28 PM
GNN60GT500's Avatar
This- Im at 10K miles with my drop- did new tires at same time- and they are not even close to wearing out. Im thinking I should get at least 20K out of them
Where did you take it to get aligned?
Whats the wear rating on your tires?
Old Mar 27, 2012 | 05:36 PM
JaE35's Avatar
Moderator
G35 Sedan
So you have aftermarket camber arms and toe bolts and still couldn't get a good alignment? No springs drop that low lol you need to find a new shop
Old Mar 27, 2012 | 07:48 PM
blnewt's Avatar
^this. Any decent shop that knows how to adjust SPC arms & toe bolts would be able to get alignment spot on w/ a mild Eibach drop. Keep looking for a better shop, no need to go back to driving a 4x4
Old Mar 28, 2012 | 08:43 AM
mishmosh's Avatar
They probably did not dremel slots for the rear toe bolts. I have Eibach with f/r spc kits and my alignment is well within stock range.
Old Mar 28, 2012 | 09:16 AM
ericks_G's Avatar
just take it to a place that gives you a lifetime alignment. thats what i plan to do with after i install my coils this weekend.
never heard of these type of problems with such a mild drop.
did you get your money back since they couldnt keep it aligned?
Old Mar 28, 2012 | 02:27 PM
blnewt's Avatar
This is probably what happened since the avg. alignment shop wouldn't mess w/ the hassle of elongating the original toe bolt slot. If that's the case it'd be a bit tough to get the toe in spec, although w/ an Eibach drop the toe should still be close.
Old Mar 28, 2012 | 04:38 PM
b-dRizZy's Avatar
WTH thats weird agreed with everyone else take it some where else.
Old Mar 29, 2012 | 09:46 AM
Fendi35's Avatar
Yea I'm planing to take it to another shop on Friday what do you mean by elongating the bolts
Old Mar 29, 2012 | 10:37 AM
mishmosh's Avatar
The rear camber arms have plenty of adjustability to correct the negative camber. However, without the toe bolts having more adjustability, you cannot zero the toe. The toe bolt kit absolutely requires you to dremel out longer slots for more travel--just replacing the stock toe bolt with the kit does absolutely nothing.
It is easy to do yourself if you are so inclined. This is the DIY that i used and it applies to our cars as well.
http://www.batit.com/forumpics/spctoeboltinstall.pdf
The toe bolt kit comes with the template. You only need to elongate the inner slots (2 per side).
Old Mar 29, 2012 | 02:03 PM
blnewt's Avatar
I used the same DIY, found it MUCH easier to use a thin cutoff wafer wheel, much easier to use the dremel perpendicular to the slot, I tried the metal cutting bit and I dulled it quick and they're like $15 a pop
Old Mar 29, 2012 | 06:10 PM
Fendi35's Avatar
Just want to say thank you guys as always I think I would have loved my car less if I ended up raising my car. Anyway an update called a mechenaic I should went to this guy first he quoted me for aligment and elongating the holes all for 75 - 100. Going to do this next week sometime. Again thank you guys. And I will keep updating
