is it possible to update the firmware of a 2008 g35 with a new one ?
Apr 17, 2012 | 01:45 AM
I ask because the Bluetooth on 2011 g37s have wider options for phone pairing, as well as advanced options like phonebook download etc..
Has anyone tried updating the firmware, if it exists, or maybe installing a Bluetooth from a newer g sedan?
Reply 0
Apr 17, 2012 | 10:57 PM
also was curious on this i am doubtful
Reply 0
Apr 17, 2012 | 11:08 PM
If the Bluetooth is a separate unit that's removable, I would love to yank the current one out and add this... but I looked everywhere, there's no mention of an update CD or a way to physically replace the Bluetooth that I see..
Reply 0
Apr 17, 2012 | 11:15 PM
I would say theoretically it is possible because of the similarities in the setup. But I think you would need to do a full swap, so the bluetooth, aux ports, iPod connection, and the HDD setup would need to be done up with the newer components. Either way all I see is $$$ thinking about what it would cost if even possible. But I am no expert. Just a computer geek. =P
Reply 0
Apr 17, 2012 | 11:20 PM
I was able to download my phonebook with no issues on my 07. Took a bit of tinkering with my droid but finally got it, so it's possible.
Reply 0
Apr 17, 2012 | 11:36 PM
How? I have a DROIDX and droidx2 and on infinitis site they both state that downloading phonebook is not supported
Reply 0
Apr 17, 2012 | 11:38 PM
Care to tell us how you made that possible bro? I just switched from Android to Windows Phone today so it'll take some research for me on that end.
Reply 0
Apr 17, 2012 | 11:56 PM
It was months ago but I remember reading thru the manual and realizing I needed a was to transfer my contacts via bluetooth so I searched the Android market for an app but forget the name I ended up using. It was something like Bluetooth file transfer or something similar.
I launched the app and initiated a phonebook download in the car and then pushed via the bluetooth data transfer app and it accepted it it after a couple of tries.
Let me sleep on it and if I have time tomorrow i will see if I can dig up the app name, i've since removed it from my phone.
Also, I think there were a couple of thereads here that may have helped me as well
Reply 0
Apr 17, 2012 | 11:57 PM
https://g35driver.com/forums/g35-sed...ok-via-bt.html
LOL, I even thanked the post back in october
here is a link to the App
https://play.google.com/store/apps/d...51bGwsMSwyLDNd
As far as i remember, i think i had to choose contacts one by one but not sure. I only downloaded about 20 of my closest friends and family.
Reply 0
Apr 18, 2012 | 04:20 PM
Says my car lacks OBEX service
Reply 0
Apr 18, 2012 | 06:23 PM
Who says that? your phone?
Do you have navigation? not sure if it matters.
Reply 0
Apr 18, 2012 | 06:30 PM
Quote: Says my car lacks OBEX service
This is what I did to get it to work. And yes I had the same error before fiddling with it. You have to go into the "settings" for your navi unit and then get into the phone settings and get to the part where you have the option of downloading the phonebook. Now first start the process on your Android phone with the Bluetooth File Transfer app that lets your transfer your contacts. Once you select your car from the bluetooth devices and you start the transfer, immediately start the process for downloading the phonebook from your car. If you do this at the correct time your car will start downloading the phonebook. It worked for me. If you want more specific instructions it'll have to wait till tonight when I get get back in my car for the procedure.
Reply 0
Apr 18, 2012 | 06:37 PM
I don't have a navigation unit built in
Reply 0
Apr 18, 2012 | 06:40 PM
Quote: I don't have a navigation unit built in
I am pretty sure bluetooth comes with the car even if it doesn't have navigation so the steps should be the same. I probably should have just referred to it as the head unit instead of the navi but the phone options should be the same as well as the process I mentioned. Albeit a really rough explanation of the process lol
Reply 0
Apr 18, 2012 | 06:45 PM
I could not find any option for downloading a phonebook in the car.... where would it be? Under settings?
Reply 0
