G35 S Emblem
Hey all,
So the red S emblem on my G35 is is starting to peel away. I'm referring to the red paint color, not the emblem itself. How should I go about fixing this? After a little research, it looks like I can order a new G35 S emblem and just stick it on there - what do you all suggest?
Thanks!
Thanks!
Hey all,
Thanks!
Thanks!
Use heat, waxed dental floss and some bug&tar remover or other gentle glue removing product.
Look for 'debadging' in the DIY's
https://g35driver.com/forums/body-in...hting-diy-232/
The physical emblem itself is not peeling off - just the red coating on top of the S emblem is coming off.
I'll post some pics up later when I get off work.
It's not that bad at all. It's coming off at the top of the S. It's just bugging me. Mainly because I just got it (used), but still - I'm trying to get it looking good.
I know how you feel man. I keep getting called OCD by my parents because I have been going to detail shop after detail shop trying to get this weird smudge off of my trunk that's been there since I bought it used. But at least you got the hookup from Grubbs Infiniti for a new emblem =)
Believe me its SUPER easy just watch a few vids on youtube for 'debadging' to gain some confidence. Just take some dental floss and slide between the trunk and the emblem and will come right off without leaving behind any 3m tape.
And since u will be replacing it with a new 'S' u dont even have to spend hours cleaning the shadow left behind by the old one and will know exactly how to place it
once u take the old one off with some heat(not required) you should be able to take the 'S' off without leaving behind any traces of the 3m tape behind, basically making sure that the the new 'S' is attached to the trunk surface and not to some leftover 3m tape making the new S sticking out more. What i meant was that you dont need to clean the 'shadowing' left behind since it will be covered with new 'S' but make sure that no 3m tape is left behind... doe sit make sense?
As i said u should be able to get everything off as one piece with the tape but IF u have no heat source and some of the 3M tape is left behind, it can easily be removed with some rubbing with a wet towel OR some 'goo gone' IF its stuck on there good(rare). Then one wipe with rubbing alcohol(optional) and put on the new one.
Believe me it really is easy and once you get the floss between the two and start pulling down you will realize how easy it really is.
What do you mean by shadowing exactly?
Sorry for my lack of knowledge by the way. I appreciate the help.
