Break Squeal
Old Apr 30, 2012 | 11:28 PM
  #31
Nate503's Avatar
Looks like I'm going to call the Infiniti dealership tomorrow and see if I can get an estimate on this.
When I call to discuss this issue - do I mention that it's a TSB and reference ITB11-050?
Old Apr 30, 2012 | 11:48 PM
  #32
kool_yaar's Avatar
u can but some dealers dont like it and say that they will need to 'diagnose' the problem themselves and see if TSB applies or not
Old May 1, 2012 | 12:00 AM
  #33
vqsmile's Avatar
^^ What kool says is very true.
If you are looking for a bargain, you may have to do some haggling with the service rep. In theory, you should be able to state what service you want performed, and have them quote a price to do it on a time and material basis; no diagnosing involved. However, if that doesn't fix it, you'll have zero leverage to making them fix the problem that you didn't let them diagnose in the first place. To just replace the pins, I can't see a justification for milking it for more than an hour, and come to think of it, the labor to perform the tsb is probably listed in the tsb documentation, though it may be coded. Anyway, they really shouldn't charge more than an hour plus the parts. They could rape you on the parts costs though. I've seen some ridiculous parts costs from some dealers. It all depends. Good luck, and let us know how it goes.
Old May 1, 2012 | 02:26 AM
  #34
Nate503's Avatar
I see what you guys mean. So what would your guys' recommendations be for me in this situation. Just have them diagnose the problem instead to ensure it actually gets fixed?
Old May 1, 2012 | 09:18 AM
  #35
rpm&my_G35's Avatar
Let Infiniti service diagnose the problem.
- If it turns out that the problem falls within the scope of the TSB (warranty also required) then you don't pay for anything, including the diagnosis fee.
- If the diagnosis turns out be be unrelated to the TSB, well, now at least you know what the problem is and you can take the steps needed to make repairs. Get a copy of the diagnosis and a quote from the dealer. Then I would take it elsewhere for another quote, showing them the Infiniti diagnosis.
Old May 1, 2012 | 08:31 PM
  #36
kool_yaar's Avatar
^ since i think he said he's out of bumper-to-bumper warranty he will have to pay for it even if its TSB like u said.
OP if you dont have a local mechanic that can change out the pins for u then letting them diagnose is better since they will have to make sure the cure the problem to charge u in full
Old May 1, 2012 | 10:52 PM
  #37
RedBaronK's Avatar
Well took in my car today for the squeaking... ummm they didn't call back, so I'm assuming its more than just squeaking ..... ill find out tomorrow.
I had the rotors replaced already cause of the "judder"/warping issue... the service rep said it can happen again even with the new rotors I have been driving on. Is this possible? Are oem rotors this bad?
Old May 1, 2012 | 11:22 PM
  #38
vqsmile's Avatar
Originally Posted by RedBaronK
... Are oem rotors this bad?
In my experience, YES.
Old May 1, 2012 | 11:29 PM
  #39
kool_yaar's Avatar
^whs stock rotor are low to moderate grade, there are a few things you can do to prolong rotors life...
Make sure the wheels are properly torqued to 80ft/lbs and not more(yes over tightening has been shown to hasten rotor warpage), let brakes cool down before spraying them with water when washing your car/wheels, get ceramic pads(they are more gentle on your rotors than the semi-metalic ones) and obviously avoid hard braking.
Keep us posted on what they say, sometimes they dont call back when they have been busy and havent got a chance to check your car out properly
Old May 1, 2012 | 11:40 PM
  #40
vqsmile's Avatar
^^ Yep. For me, it was always the hard braking that took the toll on the poor things.
Old May 2, 2012 | 02:27 PM
  #41
RedBaronK's Avatar
****... I hard brake, and I also washed my car after driving while the rotors were hot.... as well as accidentally touching puddles of water while driving.
In short....woe is me :/
Old Jun 4, 2012 | 06:33 PM
  #42
Nate503's Avatar
So I took in my G a couple weeks back. They diagnosed my braking squeal and came back with NOTHING. I didn't mention anything about the TSB as you guys recommended. They said the brakes looked fine. They said they could resurface the breaks for $200 each pair ($400 total). Obviously, they said this wouldn't guarantee it would fix the squeal.
Any thoughts? Should I take it elsewhere - ask Infiniti about the TSB? Get my brakes resurfaced and cleaned somewhere else? I know there are a number of places who should be able to do that for much less.
Old Jun 4, 2012 | 06:57 PM
  #43
RedBaronK's Avatar
Just on the resurfacing its 200?!?!!?? Are they smoking crack laced with bath salts???? No way in hell is that reasonable... its not even a replacement
Old Jun 4, 2012 | 07:13 PM
  #44
Nate503's Avatar
Yes, it consisted of resurfacing the breaks and cleaning the rotors. Though, I'll double check with the papers they sent back with me.
Old Jun 4, 2012 | 07:22 PM
  #45
RedBaronK's Avatar
Tell those motherless crooks ur not retarded. 300 bucks is what a typical dealer charges for replacing pads and resurfacing.
Ur better off going to a Nissan dealership cause it's cheaper
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
toadfire
Sep 21, 2015 07:15 AM
3000vr4tt
Sep 7, 2015 12:48 AM
